Still leaking oil
Old Jul 23, 2005 | 11:34 AM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Still leaking oil
The car is running again, no major problems. But the initial reason why I ripped out the dist.(besides the re-build) was not solved. The O-RIng in the dist was not the problem and I'm still leaking a good amount of oil from the front of my oil pan case. I can't tell if its a seal just from visual inspection due to a cross member blocking the top part of the case, and from a hood view there doesn't seem to be any visual leaks. Any suggestions?
Old Jul 24, 2005 | 12:13 PM
KED85's Avatar
SO SIMPLE
Solve it by inserting the 3.4 mill ya scored!
Serious, stop wasting time chasing a dead ghost.
Serious, the "leak" will be fixed upon the effort laid upon new donor engine. That's why I suggest ya take time with reassembly. To prevent those leaks appearing in future. I have a "few leaks" but with lessons learned from the intial swap, I can control them.
Keep adding oil easier to fix the leak that way.
Old Jul 24, 2005 | 10:19 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I agree, but, i grow weary of the puddles of oil in my driveway now I have requested the time off, and the date is set. So soon, yet so far, the questions will soon be rolling in.
Old Jul 24, 2005 | 10:33 PM
stroked1990RS's Avatar
Car: 1988 formula 350
Axle/Gears: 373
did you degrease the motor and the let it run to see were its comming from? i know you said it was tight but you should be able to see something
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
