idle air....
Old Aug 6, 2005 | 03:14 PM
mmadreman's Avatar
Car: 88 camaro
Engine: 2.8 mpfi v6
Transmission: 5 speed
idle air....
ok,,had some problems with my tps wires,, but got it figured out and reset.. now,i plug my idle air back in and fire it up...it hits about 2500 rpm and wont come back down... so, i start over,,, ground the idle sensor, recheck the tps,set my rpm to 600with the i a c unpluged,turn it off,, reconnect it,, wait for awhile,,start it up and it idles about fine, i turn it off again, so it can reset,, start back up , and it goes to 2500 and climbing again..... so, i take out the iac valve, pull the pintle out a bit, put it back in, and dont connect the plug to it.... i start it, and it idles sweet.... my vacuum is fine, at about-40 to - 45 and steady.... any other sugestions................thanks
Old Aug 7, 2005 | 11:38 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
plug the motor back in and drive the car above 40mph. This resets the IAC motor. Lets the computer know where everything is.
Everytime I replace an IAC, I've never done that long freakin' Idle learn procedure," I just drive the car above 40 and then the idle comes back down.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
