Should i add a oil cooler?
Old Aug 5, 2005 | 02:57 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
well its coming up on the time to start assembly of my new motor, and i was wondering if i should go with a oil cooler.
i figure it couldn't hurt only help.
any opinions?
its a 2.8 thats getting the ari 3.1 stroker kit, phase 2 cam with crane 1.52 roller tip rockers, and ported heads.
still waiting on an intake manifold that impresses me. the truleo is way to expensive for being steel, i'm hoping am91 gets one or doward puts on out
Old Aug 5, 2005 | 03:03 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Winters coming
Old Aug 5, 2005 | 03:20 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
winters here consist of alot of rain, and the rare snow storm, although the last few years we've had a few bad years
Old Aug 5, 2005 | 10:33 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Just run synthetic oil. Corvettes all lost their oil coolers in 1993 when they started coming from the factory with Mobile 1 in the crankcase.
Old Aug 6, 2005 | 07:24 AM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
use the cooler anda remote mount filter and for the mount on that remote mount run it for the v8 filter
Old Aug 6, 2005 | 02:10 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I run Mobil 1 EP 15w50 ($24 for a jug of 5 qts @ wally world!) + Delco PF52 oil filter (larger one)
The only way to really tell if you need an oil cooler, is to check your oil temps. I don't like mine to be more than 200º
If you can spring for it, get a *good* bar and plate style cooler - I intend to get one later, but for now it's not needed.
Old Aug 6, 2005 | 02:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well this motor isn't gonna be together for a while as the one in my car is fine, i'm just getting all the parts and everything organized to do the build all at once.
and since this new motor i want ot last for a very long time, i'm trying to find the best list of parts to do it right the first time
Old Aug 6, 2005 | 03:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Listen to D.
I would work more on water temp.
My car was a slug once the temp rose to "normal stock"
With a constant lower temp range my car runs crisp and responsive all the time. If you get them water temps below 200 you know the oil temp is fine.
Old Aug 6, 2005 | 04:36 PM
Doward's Avatar
Yes, if I had the choice between a nice aluminum radiator, or an oil cooler, I'd do the aluminum radiator. The cooler the motor, the cooler the oil will run.
I will say this - if you decide to get an oil cooler, get one with a thermostatic bypass
Old Aug 6, 2005 | 04:41 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
sounds good thanks doward
Old Aug 6, 2005 | 05:03 PM
Doward's Avatar
A couple of suggestions....
a) go with 1.6 rockers, full roller. Be sure to rebuild your heads accordingly, and go ahead and port them out.
b) the Phase 2 is an EXACT copy of the Melling MTC-5 camshaft available through Autozone for $108. Just keep that in mind.
c) roller timing chain.
d) the 3.4 oil pump has a 3/4" pickup, instead of our 5/8" I believe the 3.1 high-volume pump from Autozone is also a 3/4" pickup. Get that oil pump
e) I'm still working on the intake. I'm redesigning it, actually, as I had a freakin' awesome dream, and saw the design that is PERFECT for our motors!! Starting from scratch again on that It'll be middle section, and upper plenum. Not saying anything till I get closer to it being complete
Old Aug 6, 2005 | 05:14 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i was thinking about going 1.6 but from what i was reading people said it was not worth the money
definatly gonna get the melling then
3.4 oil pump it is
and i was plannng on going witht he cloyles adjustable roller timing chain
thanks doward and keep us updated on the intake
Old Aug 6, 2005 | 05:59 PM
Doward's Avatar
They are. The MTC-5 cam is nice over stock, but still relatively wimpy. I would definetly recommend the 1.6 rockers - they are completely worth the money, IMHO. Otherwise, I might say stay with the 1.52s (get some full rollers, though!) and go with the Phase III cam.
Just remember you'd need the Fiero valve covers, too, with the 1.6s!
If you do choose to go with the Phase III cam, either be running a stick shift, or a higher stall automatic (something around a 2400rpm)
Old Aug 7, 2005 | 12:59 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
well, i'm already running stick, i'm seriously considering going with the 1.6 now
i'll stick witht he melling cam, i'm not looking to make this a "powerhouse v6" just something better then stock
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
