Sh*t, oil light....
Old Aug 7, 2005 | 11:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Sh*t, oil light....
Today, i was stopped in traffic after a long hard run of the engine, and my oil light came on. I have a previous post regarding a low reading on my gauge.. i chalked that up to a bad sending unit, but unless the idiot light and the gauge use the same sending unit (i doubt it), i guess i was wrong. It doesnt knock, tick or show any other signs. For it to be bearing failure... wouldnt I hear it? Any advice is welcome.
Old Aug 7, 2005 | 11:22 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Check the oil level.
Old Aug 7, 2005 | 11:35 PM
Toehead's Avatar
I just changed the oil, checked it before and after the trip for good measure.. the oil level is fine, and the oil is still golden. I just bought this car, so i dont know how long this problem has been going on. The level, if anything , is a tiny bit above full.
Old Aug 7, 2005 | 11:45 PM
Doward's Avatar
I'd get a mechanical gauge, hook that up - to verify the oil pressure. If it reads none, then look toward a new oil pump
Old Aug 7, 2005 | 11:49 PM
Toehead's Avatar
thanks for the reply. Tomorrow it's going to get inspected, get it's big red reject sticker, the go to the mechanic so he can change out the oil pump. I would do it, but I dont have a lift. Think I hurt anything running with low oil pressure for the week or so Ive been drving it? Still sounds good haha.
Old Aug 7, 2005 | 11:52 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
We have an oil light?
Old Aug 8, 2005 | 08:07 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: Sh*t, oil light....
You've got a oil light and a gauge?
edit: thanks for the dash pic. Now I understand. I've never seen the Berlinetta dash before.
Old Aug 8, 2005 | 12:07 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
i have an oil light and a guage as well
it comes wit the starship dash option with the berlinetta
http://pages.prodigy.net/berlinetta/...5Page10-11.jpg
my guage doesnt work
Old Aug 8, 2005 | 12:11 PM
Car: IROC Z
Engine: 5.7
hey what sending unit did you use to fix the guage on your berlinetta?
id like to have mine working
Old Aug 8, 2005 | 02:08 PM
Toehead's Avatar
Re: Re: Sh*t, oil light....
ya, the berlinetta has a light for everything! hahahah
Old Aug 8, 2005 | 02:11 PM
Car: IROC Z
Engine: 5.7
even an "OK" light to let you know none of the other lights are on
Old Aug 8, 2005 | 02:17 PM
Toehead's Avatar
ive never seen that one. What is the gauge to the left of the oil gauge, and 2 below the engine light? It looks like low coolant to me hahah... I cant get the damn thing to shut off, although I really havnt tried. to answer your question, I never replaced the sending unit... I used a mechanical and verified mine as correct...
Old Aug 8, 2005 | 04:24 PM
Toehead's Avatar
bad news.. I hooked up my mechanical gauge... the oil pressure is very low after it heats up, not zero, but still very low. looks like my pump needs to be replaced
Old Aug 9, 2005 | 12:46 AM
Car: IROC Z
Engine: 5.7
you try a thicker oil?
Old Aug 9, 2005 | 04:33 AM
Toehead's Avatar
naw.. i'd rather fix the problem instead of just band aiding it.
Old Aug 9, 2005 | 09:23 AM
KED85's Avatar
Don't waste your time or money.
Leave it alone.
Use a bottle of 30-50 oil or 20-50 oil & see what happens. Yes drain out old stuff first or do this next oil change.
What ya got going on is loose tolerences.
That accounts for it "sounding good".
And at ilde it's low & at speed it picks up to about 30-40 PSI?
That's fine.
Use a bottle of thicker oil or oil suppliment & drive it until it dies.
WHAT YOU SHOULD BE NOW LOOKING FOR IS A 3.4 long block to swap in.
Cost of oil stuff is like $3-$8.
Labor cost & oil pump part is like $100-$175.
The 2.8 engine is old & aged. Find a replacement block, now.
3.4 latest best score is a 40,000 used long block for $650!
People have scored 3.4s for a low as $210.
I've been up to 211,500 miles on a 2.8. I got my moneys worth.
Low oil pressure & over heating its way to death until the 3.4 swap.
Toss in oil stuff & drive it until it dies.
Old Aug 9, 2005 | 11:45 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Years ago...when the dually's oil pump went the engine blew... the shop was supposed to change the oil pump with the new engine and did not. Then they closed permenatly right before I reported the prob... They had replaced my motor with a Jasper... Well I called Jasper to report the prob. They had me take it to their repair facility. The few times the pressure fell in the dually's new motor was enought to throw some nice metal into the oil pan... so they replaced the motor again underwarrenty... installed the new oil pump this time. All was fine then! So I wuld not recommend messing around with a bad oil pump unless you are considering the 3.4 swap! You might really end up needing it!
Old Aug 9, 2005 | 06:13 PM
Toehead's Avatar
the motor only has 70,000 on it! it should be fine in the bearing department. idk. I want to investgate the pump before I write this engine off. it could even be something as simple as a blocked screen on the pump. if it needs it, I'll change the pump myself.. do you need to lift the engine or can you drop the pan without. Thanks for your help/suggestions, but i cant be without this car from more then a few days, so unless it dies I cant afford to swap the engine. Good news? I have connections and can get a new engine for veeery cheap.
Old Aug 9, 2005 | 06:27 PM
KED85's Avatar
Read my response & thry that
Meaning it's way easier to do oil change than pump change.
At 70K you shouldn't have any problems.
Oil pan remove engine from engine mounts (as in raise it).
Start searching for a 3.4 long block thru your connections & make sure it'sa RWD version w/lowest miles. 1993-1995 is the object of years desired.
Give the quick fix a try befor ya go to labor.
If ya drop oil pan may as well remove the tranny to go after the other problem gaskets, rear main seal leak & also rear cam shaft seal leak, too.
And a new Timing chain, too. THEN if all is really "good" ya got mucho miles before anymore "repairs".
Old Aug 11, 2005 | 12:14 AM
Toehead's Avatar
well, the car is in the mechanic's. We'll see what he says tomorrow.
Old Aug 12, 2005 | 03:08 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
complicated?
im to lazy right now ,,but the motor has to come out to change the oil pump right,,,,,? on a 3.1?.....also could it be his pick up unit is clogged?
Old Aug 13, 2005 | 09:23 AM
KED85's Avatar
That's correct also.
Once had my broken off plastic timing chain gear teeth in my oil pump screen.
Anyone know if Original issued 60* timing chain gears also use plastic teeth?
My example was on my 1974 Chevy engine.
Old Aug 17, 2005 | 06:08 AM
Toehead's Avatar
ok, I got it back from the mechanics. Runnin 10-40 and with a new oil pump i now have about 20-30 pounds at idle hot. Thanks for your help everybody.
Old Aug 18, 2005 | 05:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The original chain gears I pulled out of my car were all metal...
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
