MAF Arrived
Old Aug 11, 2005 | 08:48 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
MAF Arrived
Thanks to Naft, I got a maf I can gut out. It arrived today, so I got it apart. Will start assy tommorow of a gutted maf.
Anyone care to see pictures of what one looks like all taken apart before I start assy?
BTW, NAFT, thanks for the trade. Plan to ship back on monday
Old Aug 11, 2005 | 10:41 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
hey no problem man, i'd love to see pics of it torn apart though, im a sucker for the insides of things . . . been takin apart things all my life.
Old Aug 12, 2005 | 01:01 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I'm wondering why?
Old Aug 12, 2005 | 05:20 AM
Dale's Avatar
Engine: 350 S-TPI
Originally posted by Doward
I'm wondering why?
Why What?
Have pictures of it? Thats why Im asking
Why Gut it? Because I'm MAP, and dont need the maf except for the clean connections on my intake, and its plastic so it wont get as hot as metal.
Old Aug 12, 2005 | 10:06 AM
Doward's Avatar
Why gut it, sorry... LOL, I see what you're doing now - although, you'll find that it WILL be a restriction still - it's a venturi style setup.
Might I suggest some thin-walled PVC pipe? Just scuff it with some 180 grit sandpaper, and paint as desired
Old Aug 12, 2005 | 11:22 AM
Dale's Avatar
Engine: 350 S-TPI
I dont see how it will be a restriction? In fact, performance has improved since I got rid of the pipe.
I also didnt like how the pipe, or way a 3" pvc would fit into the snorkle.
Old Aug 12, 2005 | 11:25 AM
Dale's Avatar
Engine: 350 S-TPI
venturi:
1. A short tube with a constricted throat used to determine fluid pressures and velocities by measurement of differential pressures generated at the throat as a fluid traverses the tube.
2. A constricted throat in the air passage of a carburetor, causing a reduction in pressure that results in fuel vapor being drawn out of the carburetor bowl.
Please explain how the maf being gutted, is any different then a tube of pvc?
Old Aug 12, 2005 | 01:21 PM
Doward's Avatar
You'll see... while it is 3" OD, the ID is like 2.5"!
Old Aug 12, 2005 | 02:42 PM
Dale's Avatar
Engine: 350 S-TPI
didnt look that thick of material to me??
TB is only 52mm? which is like 2.04
I'll measure tonight.
Old Aug 12, 2005 | 03:28 PM
Doward's Avatar
Yes, that's very true - but do you want another restriction, upstream, even if it is less of a restriction?
Old Aug 12, 2005 | 04:46 PM
Dale's Avatar
Engine: 350 S-TPI
Old Aug 12, 2005 | 04:47 PM
Dale's Avatar
Engine: 350 S-TPI
ops
Old Aug 12, 2005 | 04:48 PM
Dale's Avatar
Engine: 350 S-TPI
Old Aug 12, 2005 | 06:40 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I just got a 3 inch rubber coupling and took some 3 inch exhaust pipe hooked the coupling to the airbox and had the exhaust pupe go to the intake. Cant even tell its there and it looks like a clean install.
Old Aug 12, 2005 | 06:55 PM
Naft's Avatar
doward just got owned
Old Aug 12, 2005 | 07:48 PM
Doward's Avatar
Dale, is that a Delco, or Bosch unit?
Mine is a Delco, and you are right - 3" ID. The odd thing is, is that the unit I looked at at work, was a Bosch unit, and looked like it had a tube run down it, to make it 2 5/8" -
Now the weird part - it didn't have that central tube - just the flat board, with the fq film.
Also, I see you have the straight MAF connector - Alan, do you still have that one you had, with the 90º angled connector? I'd swear that that is the Bosch unit!
Naft, owned? Hardly... if anything, I think we're about to find out there are 2 different style MAFs floating around. That, or that reman'd unit was boxed wrong at work
Old Aug 12, 2005 | 08:01 PM
Dale's Avatar
Engine: 350 S-TPI
I dont know the difference between the two. Its to dark now, but tommorow I will take some pics of my finished project. Will also compare to the unit I take out.
Their are a couple "lips" for like the screen, and connections on the back, but they were like 1/16 of inch tall, and I knocked them down very fast with a bit in the air drill.
Old Aug 12, 2005 | 10:03 PM
Naft's Avatar
its a genuine gm maf , as delco as they come.
Old Aug 13, 2005 | 12:31 AM
Doward's Avatar
Dale, yours looks like a Delco unit.. if I get a chance while running around in the turbo tomorrow, I'll grab a pic of the Bosch unit
Old Aug 13, 2005 | 02:46 AM
Naft's Avatar
i saw a tomco unit on ebay i think it was, the outer shell was tapered toward the middle and then it expanded to the other side. if the bosch unit is like that inside, it would make sense that the shaping is to direct the airflow . . . the circular piece inside would create a venturi similar to the tapered ID.
and what is this i hear, running in a turbo? . . . now doward, thats not really a turbo, its a foot-driven supercharger.
Old Aug 13, 2005 | 10:43 AM
Doward's Avatar
Maybe it's just because I woke up, but... huh??
lol, Cardone, Tomco, they don't actually BUILD the units - they just remanufacture them. Delco, Wells, and Bosch actually build them... as does MicroTech.
Old Aug 13, 2005 | 12:49 PM
Naft's Avatar
well, it looked totally different from any (thirdgen v6) maf ive seen, so i wasnt sure(never seen a bosch maf though)
Old Aug 13, 2005 | 01:53 PM
Dale's Avatar
Engine: 350 S-TPI
Old Aug 13, 2005 | 01:54 PM
Dale's Avatar
Engine: 350 S-TPI
Mods, delete above post please.
Old Aug 13, 2005 | 07:12 PM
Naft's Avatar
nice, now hack off the thing on the right for weight savings , that nose weight is ever so cruicial.
Old Aug 13, 2005 | 07:30 PM
Dale's Avatar
Engine: 350 S-TPI
I debated on it. But I couldnt think of a good solid way to seal that area off.
Old Aug 15, 2005 | 12:19 PM
Doward's Avatar
That's the Bosch style I was talking about, Naft... without the pics, I couldn't tell which style he had
Dale, great job - should flow nicely
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
