i think i foud my problem
Old Aug 12, 2005 | 04:10 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
ok i belive this is my problem>>.>>
THE FUEL FILLER NECK SOLDER JOINT CAN DEVELOP CRACKS OR PIN HOLE LEAKS, WHICH DOES NOT COMPLY WITH FMVSS NO. 301, "FUEL SYSTEM INTEGRITY." THE CRACKS AND HOLES CAN ALLOW FUEL VAPOR AND FUEL LEAKAGE.
now what i need to know is is this gonna be a big project i dont wanna drop the rear end
anyone?
Old Aug 12, 2005 | 08:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
First it depends upon what year your f-body is. The '91 and '92s are covered under a recall. The fix is free (maybe '90s also?)
If you want to drop the tank yourself (or need to), the rear does not need to come out. Only needs to be lowered a tad. This is accomplished by unbolting the lower shock mounts.
The gas tank is easy to drop out. OTOH, some folks have fixed this issue with epoxy. Just mix up some of the thin stuff and 'paint' it around the filler neck to tank area.
I suggest a search on the General/Engine board. Lots of info on this problem, and on R&R'ing the tank.
RBob.
Old Aug 12, 2005 | 08:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
RBob.
Sway bar endlinks prob too.
Maybe this is the gas smell on my car then. didnt know 91/92 had this issue. Wonder how to tell if specific car was fixed under the recall?
Old Aug 13, 2005 | 06:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Should be able to call the local GM dealer with the VIN of the vehicle in question.
Some neck/tank joints leak so bad the fuel stains can be seen running down the tank.
RBob.
Old Aug 13, 2005 | 09:53 AM
KED85's Avatar
1-800-222-1020 is GM Consumer Hot Line number.
They can answer you recall already honored questions.
Have VIN ready before calling & possibly expect some holding time to speak to a human.
Old Oct 18, 2005 | 12:46 PM
coz's Avatar
coz
The recall expires 10 years after the issue is published. I'm in the same boat. I'm going to try the JB Weld if I can gain access to where the filler pipe connects to the tank.
Old Oct 18, 2005 | 10:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think permatex makes a gas tank sealer putty. Try that before jbweld, just because it might hold up better to fuel.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
