next mod?
Old Aug 16, 2005 | 12:28 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
next mod?
What should be my next mod? I have the following installed already. Asp underdrive crank pulley, accel super coil, accel 8.8 wires, accel cap&rotor, dynomax catback, dynomax cat, custom cai w/K&n filter, jet 180 t-stat, tb coolant bypass.
I know everyone is going to say headers but they dont have emissions legal headers out for the 3.1 yet so im just gonna move on a buy some other mod until the headers are available.
Old Aug 16, 2005 | 01:44 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
headers
Edit, I know both U and I are waiting for Manifolds ( Intake and Exhaust)
Old Aug 16, 2005 | 02:29 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Maybe a new cam or a chip?
Old Aug 16, 2005 | 02:48 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Yeah, look through Summit and find a mild cam for the
v6 motor so this way you can just install it and be done. No need to change 50 other things on the way. A chip? Ehh.. I dont know..
Old Aug 16, 2005 | 03:01 PM
FAST RS's Avatar
I actualy saw a comp cam in jegs they had one for low to mid range power and the other was for mid range to high end power it was only like 164 and i think it came with lifters.
Old Aug 16, 2005 | 05:07 PM
goatnipples2002's Avatar
Car: Mustang
Engine: Iron head 3.1
Transmission: Muncie 4 speed
Axle/Gears: 3.65 gears
I would go with a compcams H260 cam or if you want a higher lift get a custom grind. For the custom grind just take the profile of a good v8 cam and apply it to a v6 cam stick.
I would also get the trueleo intake.
As far as the cam for low to mid vs mid to high goes...depends on if you race or just drive to work and back.
Or get some nitrous.
Plan on swapping springs also.
Old Aug 16, 2005 | 05:59 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
1.6 roller rockers + rebuild/port/polish your heads.
Do a cam swap, if you want, as well
MTC-5 from AZ for $116 - same as the ARI Phase 2 camshaft!
Old Aug 16, 2005 | 06:21 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
cam
that cam u seen in jegs is a weak cam that is used in the 3.4 engines, ive looked into the h260 before if i go turbo ill get that cam (slightly more aggressive than the mtc-5 and ramps up faster) if i go all motor or supercharger im getting the more aggressive h272
Old Aug 16, 2005 | 06:43 PM
Car: Mustang
Re: cam
The only reason I mentioned the H260 is because I have heard many stories about crane being poor quality. I personally won't run crane. That is why I said custom cam which is about $175. Your money your car.
Old Aug 16, 2005 | 06:45 PM
FAST RS's Avatar
Which cam would be better for raceing the low to mid cam or the mid to high cam? I basicly when i rebuild my engine jsut want a very mild cam since my camaro is a daily driver and i know my engine is on its way out.
Old Aug 18, 2005 | 04:00 PM
Car: Mustang
I would run the Comp Cams H260 because it increases performnace and gas mileage. Not both at the same time. Depends on how much pedal you apply.
For which is better.....When you race usually you don't go very low in rpms. I launch at about 3-3.5k, then while racing I shift as fast as possible to keep the revs up. So with that...I would suggest a mid to high cam. The H260 is good from 1k to 5k so that is good for pretty much all driving, very broad powerband. It is a single pattern cam meaning the intake and exhaust lifts are the same. This helps for peak power which is good in racing and for things like nitrous. You can get a dual pattern like the Crane 272 which has a narrower powerband. All fieros idle at 1k so my cam is in it's powerband from idle. I noticed the difference between the stock and this one instantly. It pulls way harder, like I was bobbing head to a good song. Comp says this cam has an excellent top end and a lope at idle. That's all they say...no lope...the top end is excellent and the low is better too.
Could also raise the compression by milling the heads.
Polish the heads and IF you know what you're doing port'em too. But if you don't know how to port you can't do any damage with polishing.
Gasket match everything.
If you need more "umpf" put 1.7 rocker arms. Yes I meant 1.7
None of these mods together will even hold a candle to the truleo intake. This intake magnifiies any mod after it.
Old Aug 18, 2005 | 10:37 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Nitrous?
Forced Induction?
Old Aug 18, 2005 | 11:09 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
but for over 600 you could get new rockers cam and a head port and polish, imho that intake is overpriced
Old Aug 19, 2005 | 10:27 AM
Car: Mustang
Yes you are right it is expensive, but the mods you mentioned will only be as good as the intake flows. Weak flow equals weak gains, high flow equals high gains.
But most of the cams available for our engines makes peak power at or around 5k so the intake will only help on the top end.
Old Aug 21, 2005 | 07:02 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Cam Swap
I have a 2.8 and went with the following cam 173-207 60° High Energy 240H Cam which I purchased from CompCams. It works fine with the stock computer or you can upgrade the chip for an extra 10 to 15 horsepower. You can also get the street legal chip without having to upgrade the thermostat. Your call!
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
