Adjusting Hydrolic lifters
Old Aug 25, 2005 | 04:42 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Well here is the problem. I just installed a new cam and everything was fine till the first run. Once I got a good pressure build up on the lifters the engine stopped. My solution is that I have over adjusted them. Well I went right by the book tightened them to 0 lash then 3/4 turns after that. So what I need help with is, is there a possiblilty of adjusting these things another way? Unlike the carborated engines you can leave the valve covers off and do it that way but with the fuel injected 2.8s you know there is this thing called the plemeum ( check the spelling) and you can't start the engine with it off. My other solution is to take the p thing off, remove the valve covers, put it back on, adjust the lifters, then put it all back together again. That way I know its right. Alot of work but it will be right and I won't have to worry about it again.
So I am taking all suggestions but please post before tomorrow morning b/c thats when I start my journey.
Thanks,
Derick ( 2.8L V6 freak) LOL
Old Aug 25, 2005 | 10:21 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
GM manual says 1.5 turns past 0 lash for setting valve lash. It seems like I remember some guys on here having no problems with the 3/4 turn thing... but I've had nothing but valvetrain noise with mine and I broke the cam/lifters in with 3/4 turn.
No suggestion on the engine stoppage though mang.
-Bud
Old Aug 26, 2005 | 09:02 AM
mvftw's Avatar
First ? is, how did you 'find' zero lash??? The rest is easy...
Old Aug 26, 2005 | 09:29 AM
wildponies3's Avatar
Car: 87 camaro(Temporary insanitee)
Engine: 2.8
Transmission: Non worldclass t-5
what does the cam manufacturer suggest, i would go by their suggestions, not the factory's as the factory did that for stock parts!
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
