Oil Pressure drop
Old Sep 3, 2005 | 10:44 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Oil Pressure drop
I just finished putting a new cam and lifters in my car and now I have another issue. What happens is the car runs fine with good oil pressure around 40 and then after running for about 5 mins or so it drops to 0. I plan on dropping the oil pan and checking the filter this weekend but can there be another issue besides that? Starts off fine so I'm hoping is just a clogged filter. Any other things I should look for.
Old Sep 4, 2005 | 05:00 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
What kind of oil are you running?
If it's too thin, you'll get issues. How many miles are on the engine? When the bearings wear, you need thicker oil in there because the thinner oil just slips right out of the bearings because of the worn tolerances.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
