"Im leaking oil"
Old Sep 11, 2005 | 11:12 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
"Im leaking oil"
ok had the R/S up in the air and noticed some wetness on the trans pan.,., during closer inspection., from the passenger side and using a not so high floor jack .,., i could see that it is oil,.,. some of it is on the tip of the starter and appears to be on the bell housing,.., ok now what im hoping not to hear is that its a rear engine seal.,,.,. Please *** im hoping some one can tell me its a sending unit or sumthing,.., any way maby someone could tell me what they think,.with there knowledge of the 3.1
Do you think it is something besides the seal.,.,,. i mean unless the starter is kickin it up to the back of the trans housing.,., why would the housing be wet????
oh also one more thing my oil gauge also has been fluxuating during running at idel.......
Old Sep 12, 2005 | 09:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's probably the distributor o-ring seal. Over time, it hardens up and gets cracks in it (like any rubber seal or rubber hose does), and starts leaking thru the cracks.
It's a 1/8th inch thick, 1 inch inside diameter o-ring. Go right to a GM dealer for it because no other parts store ever knows about this part.
Old Sep 12, 2005 | 05:11 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Right you are, Tom. "You want a distributor what? I can sell you a distributor.....a whole one!"
Dist. gasket always looks like rear main or oil pan or whatever else, it gets all over the place.
And your oil gauge fluctuation....did it do it before? GM gauges arent exactly top-shelf equipment and what youre describing sounds fairly normal to me, being that it's from an old factory gauge.
Old Sep 12, 2005 | 05:20 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Hah! LOL There always seems to be someone that says "but I (insert absolutely opposite experience here)..." I get to be the one that got a o-ring at Autozone! I asked for it, they looked it up in computer and gave me one!
I also put a SBC distributor base gasket on mine.
Old Sep 12, 2005 | 06:53 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
It could also be the rear seal on the intake manifold. I had a bad leak, and I replaced the o-ring and it still leaked. Turns out I had a dryed out seal on the rear of the intake manifold. Just a thought.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
