Just compleated installing new water pump!
Old Sep 30, 2005 | 05:23 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
Ok i just did the water pump yesterday!, ok i was wrong, i did have to remove the powerstearing bracket,because a bolt held the pump on thru the bracket.,thus sharing a bolt.,and a bolt from the ac mounting.,other then that no problems., I got a 1 yr waranty from auto zone.,for 15$ after a $10 core.,
Get this!., I bought some tacky "high temp"atv gasket sealer,.and the sum bi*** exploded in the package just sittin on my dash board.,luckly it was still in the bag., I took it back to auto zone! and they were suprised.,and refunded me no prob,.i already had enough for the job.,
One thing i still cant understand: Is that when my pump was removed my timing cover was still held in place with outer bolts,.unlike what i was told here! i have a 91 r/s 3.1 how come mine was not like every one else's?
Over all the job was very easy,.scraping the old gasket was a lil tidious!,.I used a pocket knife.,and a razor blade.,took my time and bumped some tunes.,.,
Oh and the pump did not have torx head bolts.,im guessing that is an indication it has been rebuilt befor?
Old Sep 30, 2005 | 09:58 PM
wizman073's Avatar
Car: 1987 Firebird
Engine: LB8, 2.8L V6
Transmission: t-5
I am in the middle of replacing my water pump too. You are mighty lucky that those were not torx heads! I had to grind the head off of one of the big ones cuz I couldnt get it to turn, and then heat it insanely and took forever to get the stud to turn (with a pair of vice-grips). I didnt have so much trouble with the gasket tho, as I used a wire-wheel very carefully to remove it. Also, when I got the trouble bolt off, coolant started pouring out from behind where the bolt was. I am 2 days into it right now (this is being done during free periods at school), and I have finally gotten everything preped to start putting the new pump on and reassembling.
Old Oct 1, 2005 | 12:54 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Ya no torx bolts on the 91 i know that for sure and there are more bolts that hold your timing cover on if i remeber its been a while since i changed my waterpump.
Old Oct 1, 2005 | 06:02 AM
KED85's Avatar
The cover is held in by "glue".
One prys it off when "removing".
Ya should have considered a new timing chain while in there.
Attached Thumbnails Just compleated installing new water pump!-ready4duty2-.jpg
Old Oct 1, 2005 | 11:32 AM
gottfuel's Avatar
nope
no! my timing chain was still bein held in by a few more bolt's, after the pump was removed!! i realy got in there and looked! because i was told to becarfull not to pry the timing cover off., i know for sure it was held on by a few bolt's cause i was tapping the old pump out with a hammer! as far as my timing chain goes,.,Yea i suppose i coulda done it but it dosent have many miles on it any way! so i should be good to go...................
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
