Do I need a new computer if I swap in a 3.4?
Old Oct 24, 2005 | 12:04 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
I was talking to my mechanic and he was telling me that I need a new computer. Is this true?
Old Oct 24, 2005 | 12:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Moving from Engine Swap to V6.
Old Oct 24, 2005 | 01:06 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
No, it is not true.
Just swap over your intake and accessories and the 2.8 ECM will work fine.
Old Oct 24, 2005 | 09:23 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
read up on KED85s (miss you) tech article on the 3.4 swap and youll learn a lot about this swap. then do a search and read up on any of the long posts. you reuse the 2.8 intake, fuel rail, timing cover, oil pan(optional depending on what year i think), use the 3.4 flywheel, balancer, injectors. check out the tech article, thatll answer most of your questions. the rest should be answered by a good thorough search. trust me, ive been there, i believe i was only the second to swap a 3.4 into a manual, and the other guy was no longer on the boards when i did it.
Old Oct 25, 2005 | 02:03 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you reuse the intake and soone asks you to open the hood (potential racer, cop, emissions inspector) it will look stock. noice
Old Oct 25, 2005 | 03:44 PM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
hmm so switching from a 60* to a 90* wouldnt matter what the computer was ?
Old Oct 25, 2005 | 04:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
they're both 60* engines.
THe 3800 is a 90* engien w/the 60* bell housing pattern.
Old Oct 25, 2005 | 07:03 PM
Engine: 364ci LS2
Axle/Gears: 3.46
oh whoops, i thought it said 3.8
midge54
Jan 29, 2017 07:00 PM
E Rod
Aug 28, 2015 05:17 AM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
