2 weeks. Dead.
Old Oct 25, 2005 | 10:17 PM
ladiesmanwc's Avatar
Car: 87 Firebird
Engine: 2.8 V6 - bone friggin stock
2 weeks. Dead.
I got my 87 Firebird about two weeks ago. Ran like a dream. Today, coming home, boom. Dead. Overheated or something. Smoking like a mad man. It's start up and idle, but once it goes into Drive it stalls. And the engine is knocking horribly.
How come I can't get one of those old people cars that runs forever with parts falling off it? Mine go from "runs like a dream" to "3 ton paperweight" with no inbetween.
I wanted a third-gen for as long as I can remember. Had one for 2 weeks. Now I have no money to fix it, and no money to replace it. Horay.
Old Oct 25, 2005 | 11:54 PM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
I would use this opertunity to do an engine upgrade (if you're set on keeping a 2.8/3.1 or to do a swap. You would be amazed how cheaply you can get a t-5 and a carbed 350 for (by far the cheapest combo).
Old Oct 25, 2005 | 11:57 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Check your oil and see if it looks like chocolate milk that would be a blown head gasket. What color was the smoke comeing out of the engine or was it comeing out the exhaust? Before you bought it had it been sitting a while? Did you change the oil after you got it?
Old Oct 26, 2005 | 01:36 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 2 weeks. Dead.
Originally posted by ladiesmanwc
"3 ton paperweight"
On the bright side at least it's only about 1 1/2 tons...
Old Oct 26, 2005 | 09:12 PM
Car: 87 Firebird
I do plan on keeping it and swapping something in there. The problem is, that was my driver. I have no car at the moment.
That's exactly what I want though, a carbed 350 (keeping auto....I just don't like driving manual.)
This is going to end up being my first project car. I actually don't know much about HOW to things (I know what things to do, lol), but this is a good opportunity to learn. If I break something....it doesn't matter. It's already broken.
I can't be too upset. The car cost me $800. The body alone was worth it. It just sucks because up the creek without a paddle with no car. Heh, you're looking at (probably) a Kia driver!
Old Oct 27, 2005 | 11:34 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if youre looking for quick, easy, cheap, and simple. get a 3.4 and swap that in. not only is it all of the above, but it gets you more power as well. look into KED85s swap boogie and do a search on this swap and do a search, itll answer a lot. its worth it!!
Old Oct 28, 2005 | 01:12 PM
Car: 87 Firebird
That might be an idea, too. It'll come down to if I think I have the patience to do a V8 swap or not. At this point, i've written off the car as a driver for the moment, so now I have all the time in the world to do whatever to it.
Old Oct 31, 2005 | 08:00 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Baaah, you people always complainin...just top off the oil and coolant, start her up, put a spacer behind the throttle blade or drill out and adjust the stop-screw to raise the idle to like 1500....and drive with 1 foot hovering the brake and 1 foot over the gas pedal. You'd be amazed at what you can actually drive if you really try
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Linson
Sep 21, 2015 01:08 PM
david068513
Sep 18, 2015 10:36 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
