Will a 2.8/3.4 oil pan work on my 3.1
Old Oct 29, 2005 | 08:31 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I know that the 2.8 will most likely work, but I'm unsure as to whether or not there will be clearance issues underneath the sub frame. Same idea with the 3.4, I think I know the block is the same, but will there be clearance issues? Same bolt patterns on the pan? Just those general questions.
Old Oct 29, 2005 | 08:59 PM
V6#22's Avatar
Post Removed
Old Oct 30, 2005 | 08:07 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
you can use the 2.8 timing cover and the 3.4 oil pan, i did when i did my 3.4 swap due to my 2.8 pan having some dents in it and just being in overall worse condition.
Old Oct 30, 2005 | 10:28 AM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
alright thanks guys, its becoming more difficult than I thought to find a 3.1 pan, so I'll try and get the 2.8 and be done with it. thanks for your info
Old Oct 30, 2005 | 11:37 AM
V6#22's Avatar
Post Removed
Old Oct 30, 2005 | 12:26 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
some (possibly s-10s) had a different timing cover and oil pan...the mating surface between the two was at an angle rather than "flat".
and, the 3.4 timing covers don't have the timing tab to set the timing correctly since they had the DIS ignition.
Old Oct 30, 2005 | 02:45 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
pre 88 pans will not fit anything 88 and up, otherwise they all fit
Old Oct 30, 2005 | 09:24 PM
drdave88's Avatar
Engine: 6.0L
im not sure of the pre-serp ones. but anything w/ a serp setup should work. just not sure about before then. if i get a chance, ill check out my grandmas 85 camaro(yes my grandma has a camaro, lol), its the v-belt setup, ill see how that looks, it may not be for a couple days though. anyone swap a 3.4 in a pre 86 2.8 and use the 3.4 pan?
Old Oct 30, 2005 | 10:17 PM
V6#22's Avatar
Post Removed
Old Nov 1, 2005 | 07:35 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
why not just get another 2.8 oil pan and timing cover from a junkyard or something? The 2.8 pan and cover should fit the 3.4 right?
Old Nov 1, 2005 | 09:07 PM
V6#23's Avatar
Post Removed
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
