No Power!!
Old Nov 7, 2005 | 07:38 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
No Power!!
Might possibly be low on gas but as soon as I come to a slight incline there is absolutely no power what so ever and there is a bottom end knock like crazy or its back firing like a mo fo. Please help me. I just replaced the injectors and filter so I dont think its fuel related. O2 sensor maybe? Thanks for your help in advance, Baron
Old Nov 7, 2005 | 08:05 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
fuel pump.
Fill it up, if problem goes away, I bet money its a pump and it will return once it gets low again.
Also check your oil.
Also, if the bottom end is knocking, its activating the knock sensors, which retards timing, which = less power.
Old Nov 7, 2005 | 08:35 PM
Oil doesnt have more than 50 miles on it, so I doupt its that. Ill check the timing tomorrow.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
