a few issues with my carbed 2.8
Old Nov 9, 2005 | 11:09 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
ill list off the issues if anybody can shed ANY light on to any of my questions thanks in advance, im trying to condense all my questions into one post
1) Ive noticed lately that my Check Engine light has been coming on, but when i check for codes (useing not only the paper clip method, but with a scanner as well) Theres no codes to be found????? any ideas?
2) ONLY when im acclerating (3/4ths to full open) i hear a fast Tick tick tick, could i be hearing a Lifter tick? this is the only time i hear the ticking, and i have my windows down all the time.
thanks again for any help guys, im trying to get this 2.8 to see 100,000 miles (the way the car is right now im thinking that the previous owner didnt take too good of care of this car )
Old Nov 9, 2005 | 11:51 PM
wellington's Avatar
Car: 83 firebucket
Engine: less then a geo
Transmission: 5speed crap box
if the tick is only at high rpms it could be lifters.
are you sure you have the timing exact?
and your good pal,electrical tape should take care of that pesky check engine light.
Old Nov 10, 2005 | 12:23 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Ill have to check the timing again, Last time i checked the timeing was + or - 2 or three degrees of the timing seting on the Emmissions label,
Anything else that ticking could be? maybe an intake leak or something? (crossing my fingers that it isnt a lifter tick)
Old Nov 10, 2005 | 06:11 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
will the car make the same ticking sound if you just rev it up?
Old Nov 10, 2005 | 06:30 PM
Parrydise7's Avatar
Mechanical fuel pump?
I had this strange ticking, that I could only hear on one freeway curve, where they have the "K" rails and only when my window was down. It turned out to be the fuel pump. Damndest thing.
Old Nov 10, 2005 | 09:55 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Nope, its really pissing me off trying to figure out were its coming from.
Yea i hear the ticking as well when ever im near a curve or anyplace that will echo, I aslo hear it inside the car with the windows down/radio off. And yes it hasa Mechanical Fuel pump.
Old Nov 11, 2005 | 03:25 PM
Parrydise7's Avatar
Do you have an automotive stethescope? Sears and other places have them. That should tell you whether it is the pump or not. Good luck.
Old Nov 11, 2005 | 08:01 PM
Engine: 5.7 / 7.4
more stuff to throw out atcha:
how is the clutch for the fan?
sounds like it only makes the noise under load........
is anything loose under there that could be hitting the fan?
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
