performance with no air filter %
Old Nov 13, 2005 | 12:52 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
?.. i took the air filter out one day on my 3.1 camaro and i was expecting to hear the motor rev a lil higher, but it did not, then i took it out on the hwy, to see if it was a lil more powerful and i could not tell for the life of me.,,.does removing the aire filter increase performance ? if so how much?
Old Nov 13, 2005 | 03:16 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
not by enough to risk destroying your engine when dust/dirt/water gets in there and ruins your injectors and scores your piston walls, causing shortened engine life and reduced performance. not to mention the risk of liquid lock. i would highly advise against making more then a dyno run or two w/o an air filter.
Old Nov 13, 2005 | 12:44 PM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
You should be able to see a difference. I could tell a difference from changing my old one that was black to a new one, it felt more responsive, so I imagine if I ran it without an air filter the difference would be more.
Old Nov 13, 2005 | 01:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Some engines may not notice anything but if going from a stocker to K&N helps it breathe better, thus no air cleaner should make it flow better. Though if you live in a dusty dirty climate [sand] not good. Water isn't bad for an engine, only in large amounts. [turbo guys use water injection for a reason.] Can't see it makign your injectors dirty, unless you talking about the out side of them.
But the combustion should keep them cleaned off. Cylinder score is the big one to watch out for but I know people with old trucks and a million miles that never had an air cleaner but your climate and the fact that they are only driven 1-2times a week comes into play.
Though I only mentioned it for kicks in the other thread. On a nice day and if you have a true CAI, removing the filter should make it feel better. should, should should should, might not though if your engine is already tired.
I have done it before but ask in the carb section. I found many people here running no to minimal air filters with years of use.
Old Nov 13, 2005 | 04:46 PM
wildOne87's Avatar
Car: 87 camaro, '02 cbr600f4i, 70 mustang
Engine: 2.8/600c.c/ 351C
Transmission: Manual/Manual/Slap stick
i saw about a 1/10 second gain on a 1/8th mile strip. but then my cai is the biggest bottleneck in the entire intake system. and i have alot of work done to the engine..i... i only run no filter on the track for the gains that i get..... never do it on the road as there is way way too much dirt and dust that will score your cylinder walls after enough exposure to it...
Old Nov 13, 2005 | 05:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
In reality if no intake restriction doesn't make much of an improvement, your engine is tapped out n e ways.
An engine is just a giant air pump. If freeing up the intake doesn't help, the problem is probably on the exhaust side. Unless you got a turbo, you can't suck anymore air in , then what flows out.
But there all all kinds of exceptions to the rule.
But if you find freeing up the intake doesn't help, id start doing exhaust mods. Then start in internals.
Old Nov 13, 2005 | 06:41 PM
wildOne87's Avatar
you could not have said it better gumby, but still you don't wanna take the filters out for normal driving
Old Nov 13, 2005 | 10:29 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i have run my car at the track with no filters and it runs no different. i'm running the TPI dual snorkel air box and stock paper filters and it runs the same either way.
Old Nov 14, 2005 | 05:39 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
but stock, you're induction is a whole lot better than a stock birds
Old Nov 14, 2005 | 10:12 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If you notice a performance gain by removing the filter, you have issues that need to be worked on.
Old Nov 14, 2005 | 11:22 AM
Car: 91 Camaro
oh yeah, forgot about the bird's lovely setup. i still lean towards what Dale said after me, though.
Old Nov 18, 2005 | 05:18 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Very sound advice.
Old Nov 18, 2005 | 07:26 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Originally posted by Nate86
Very sound advice.
I agree very much on this.
the restriction from the air filter at least comparing a brand new one to no air filter provides very little restriction that is hardly even noticable.
you would gain more air flow from doing other things with the intake ducting instead.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
theurge
Aug 21, 2015 12:46 PM
