Hello And Question ..Exhaust
Car: 1986 Fiero Gt
Engine: 3.1
Transmission: 3spd / shift kit
Hey Guys Whats Up !!
Just Wanna Say Hello And That I Will Hitting This Board Alot Now ... Myself Im Partile To The Fiero But I Have Allways Liked 3rd Gens ..If Ya Want Pics Of My Fiero I Have My Website In My Sig There Outdated Pics lol
Actually Installed The 3.1 , Lowered It ..All Poly Suspesion Etc...But Enough Of Me
On To The Question
My Gf Has A 88 Firebird 2.8 Auto ...Does Anyone Have A Good Pic Of The Exhaust From The Underneath Of THe Car ...Im Yet To Get The Car On Stands To Check It Out
Also What Have Ya Guys Done For Exahust On These 2.8
Ive Got A Flowmaster 80 In The Fiero Now ..And Im Thinkin Of Going The Same Route Here As Well !
Thanks For The Space Guys ...Be Talkin To You All Later
Actually Installed The 3.1 , Lowered It ..All Poly Suspesion Etc...But Enough Of Me On To The Question
Car: a car being parted out
Engine: blown up
Transmission: in peices
The exhaust is a minor PITA to replace. Expect a good 3-4 hours for a first try.
We mainly go with the dynomax set up because alot of us do not care for the resonance of the flowmaster above 3K that it is known for here.
As far as replacing the exhaust...
It is simple till you get to the rear axle where you have to unhook the panhard bar, and maybe the shocks (some cars do, some do not) to gain the clearance.
You have to get all the weight off the rear axle and let it hang as low as possible.
Also a good cutter (cut off wheel body saw or the like) to cut the exhaust in peices as you remove it will make it easier.
Car: 1986 Fiero Gt
Engine: 3.1
Allright ...Sounds ..Not Cool lol
Thanks For The Quick Reply Buddy
Where Is The Cat Located ..And Is There Any Obsturctions Around It ..Or Should I Be Able To Cut Her Out Easy..
Prog Gonna Just Straight Pipe It For Now
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I had to remove the body brace on mine(above the panhard), but thats just 4 more bolts.
I would say 3-4 hours at home, possibly less at a shop, and someone who has experience.
Cat is under the passanger floor board. Can be removed halfway easly. You have to re-attach a bracket that is mounted to the car or else it sags. I noticed no gain by removing the cat, if anything I lost a hair of low end.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
when I got my dynomax setup on, I couldn't get the I-pipe throught the axle/panhard rod area, so I took it to the aut hobby shop & uesd a lift. I used the chassis one so teh wheels could hang down. When high enough the pipe was jsut manuvered in w/o a hitch.
Car: 1998 Camaro Z28
Engine: 6.0L
when in put my dynomax exhaust on, i also put on a catco convertor. i torched off the bolts and installed new ones. i had to drop the pass side of the panhard bar and the "body brace" bar to get the intermediate pipe out and new one in. it took me 2-3 hours to do the job. and back then i didnt have nearly as much knowledge as i do now. but i did have an assistant whos changed his own oil two times before, lol.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Good Luck Buddie. BTW Why Do You Type Every Word In Caps? Is That A Fiero Thing. "What You Think Your Betta Then Me?"
good luck on your exhaust
Car: 1986 Fiero Gt
Engine: 3.1
Perhaps It Is A Fiero Thing ..Nah Its A Old Call Center Thing ...Just Makes Lots Of Notes Look Neater Lol
So I Cant EVER Stop Typing like This ...If I Do Its A Really Bad Off Day
