2.8 and 3.4 parts interchaning
Old Nov 16, 2005 | 10:24 PM
Big4x4Ride's Avatar
Just wondering if heads from a 95 3.4 will work on a 2.8, and if I could still use the injection setup off a 3.1 with it as well.
Old Nov 16, 2005 | 10:52 PM
BigNorm's Avatar
yes. Check this out: http://web.camaross.com/forums/showt...&highlight=3.4
Old Nov 17, 2005 | 12:14 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yes... but if you're referring to a '95 3.4 from an F-body, unless your heads are toast, there's absolutely no reason to bolt 3.4 heads on. They're the same casting/valves/ports/size/shape/weight/everything/etc
Old Nov 17, 2005 | 12:22 AM
Big4x4Ride's Avatar
these are aftermarket aluminum heads im actually trying to get, just need to be sure they will fit the 2.8 and will work with 3.1 injections
Old Nov 17, 2005 | 10:20 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
if they are 60*V6 Specific heads, then they will bolt to any 60*V6 engine.
as far as the injectors, they are all the same TYPE, and SHAPE. One from a 2.8 will bolt in (may not work correctly for the # size) into a 3.1 and a 3.4.
Old Nov 17, 2005 | 12:17 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have to disagree with some info here.
1. He said 2.8, didnt state what year or injection system.
2. If you are a 2.8 carb, the valves are bigger in the FI heads.
3. The differences between FI2.8 heads and RWD3.4FI heads are so little, you wont notice it unless they are side by side.
4. a head off a fwd 6/60 will bolt onto a rwd 6/60, but you need to change the pistons, as well as use the FWD intake, and modifiy it to work with a distrib, or swap to SFI injection.
5. not all 6/60 heads are the same. There are about 4-5 different ones.
If you have found peformance aluminum heads for a 6/60, please let us know where.
futher more. The fuel injectors go in the INTAKE, not the HEADS, so heads have nothing to do with the injectors.
Old Nov 17, 2005 | 04:52 PM
Big4x4Ride's Avatar
I have a 2.8 engine out of an 85 s10 its carbed. Wantign to rebuild it, and install the aluminum heads that are coming off a 95 camaro 3.8. Then I want to put fuel injection on it using a complete setup off of a 3.1 out of a camaro. Wondering if that will work.
Old Nov 17, 2005 | 06:03 PM
Dale's Avatar
Engine: 350 S-TPI
3.8 heads wont bolt onto a 2.8. Total different block desgin. We all thought you were talking a 95 3.4
A 1985 carb 2.8 is one of the weakest blocks to build on as well.
Old Nov 17, 2005 | 06:19 PM
Big4x4Ride's Avatar
sorry mis typed it is a 95 3.4
Old Nov 17, 2005 | 08:24 PM
Dale's Avatar
Engine: 350 S-TPI
95 3.4 has steel heads. So if they are aluminum, please let us know where they came from.
Try to get the whole engine if you can.
Old Nov 17, 2005 | 08:52 PM
Big4x4Ride's Avatar
its a seto f aluminum heads on ebay right now that im looking at
Old Nov 17, 2005 | 09:30 PM
Dale's Avatar
Engine: 350 S-TPI
ok, fwd ones. you will have to change the pistons as well. Then also put the FWD intake on too.
Old Nov 17, 2005 | 09:39 PM
Big4x4Ride's Avatar
ok, scratch that idea then, im new to the v6 stuff
Old Nov 18, 2005 | 01:50 AM
BigNorm's Avatar
read that whole link I posted above.
Old Nov 18, 2005 | 09:00 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
They probably are cast iron, since there was no pushrod 3.4L in '95. The first year for the 3400 was '96 in the U-van.
That being said, there have been known to be some aluminium genI heads floating around, but are rare to find.
A link to said auction would help clear things up.
Also I wanted to state that because one might swap to a genIII top end does not mean you have to swap to SFI, I swapped to a genIII top end on my 2.8 block (stroked/bored 3.2L), and am using MPFI (batch fire). At this point you pretty much have to swap to DIS though, or build a custom intake or distributer.
Old Nov 18, 2005 | 09:03 AM
The_Raven's Avatar
Link no workie.
Old Nov 18, 2005 | 11:12 AM
BigNorm's Avatar
try camaroz28.com. copy and paste
Cleotiz
Jan 6, 2018 08:56 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
