Verifying Blocks for Main Bearing size
Old Nov 26, 2005 | 08:35 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
I was wondering how to go about verifying the year of my 2.8 engine block. I have the code off of the engine but don't know what to do with it.
The problem is I keep ordering the main bearings and keep getting the wrong ones. From my understanding there are a few types of mbs you can get for these blocks. I was told the earlier models had a smaller main bearing than some of the older ones. I'm not too sure about that but I keep getting the small bearings but I need the set with the larger rear mb.
Can anyone help me out with this. I'm getting confused.
Thanks,
Derickab
Old Nov 26, 2005 | 02:23 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
whats the engine code?
Old Nov 26, 2005 | 02:40 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Sorry I meant the serial number off of the block. Wrong choice of words.
Old Nov 26, 2005 | 05:27 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm, couldn't help you their, take the serial number into a gm dealership, they should be able to tell you, what letter is on the side of your block btw?
Old Nov 26, 2005 | 05:31 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
There's only two sizes of main bearings and they were changed as a complete change-over in mid 1985.
Are you saying that when you order bearings, there is only one that doesn't fit?
Old Nov 26, 2005 | 06:05 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
I believe there is an E on the side of the block if I'm not mistaken. This is the serial number I got off of it: 14100695M. This came off of the left or passengers side of the block.
Like you said though there was a letter on the side of it which I didn't copy down. Is that significant?
Old Nov 26, 2005 | 06:07 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
On the first set I ordered only the front mb would fit. The other 3 were too small. This set I just got in today might work but I have to get over to my dads tomorrow and give them a shot.
Old Nov 26, 2005 | 06:25 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
hmm, i was asking because my 3.4 has an f and a 2.8 that i have has an l on it its supposed to be an 88 block, so maybe you have a 85 or earlier block.
again i never verified what year the 2.8 was
Old Nov 26, 2005 | 08:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Didn't the bearing change come along with the internal balance?
Should be pretty easy to tell them apart.
External balanced with the flywheel, or internal balanced on the crank. Making it necessary for bigger bearings.
Old Nov 26, 2005 | 08:17 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Grumby,
I think that is my issue. I never did specify weather it was internal or externally balanced. It is internal though so I think you have just solved my problem. Never thought of it until I read your post.
Thanks,
Derickab
Old Nov 27, 2005 | 02:17 AM
The_Raven's Avatar
No, the main bearing size changed in mid '85, the change to internal balance happened in '87.
Old Nov 27, 2005 | 10:42 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Thanks for the info everyone the bearings I picked up the other day(friday) work out for me. Looking to be back on the road soon.
Old Nov 28, 2005 | 10:11 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Well eveything is good now so I have started reassembling my engine today. The mains are 40 over and the rods are 30( bearings).
Going to take a while since I have to travel out of town this week but hopefully I will be back up and running in about a week or two. Will keep you all posted.
anesthes
Mar 10, 2016 10:35 PM
toronto formula
Nov 10, 2015 06:17 AM
xxx3man`
Sep 23, 2015 10:37 PM
knight72
Aug 10, 2015 09:32 PM
