engine problem??
Old Dec 18, 2005 | 11:55 PM
umpire's Avatar
engine problem??
2.8l fuel inject. starts up fine. sounds good idles good. put into gear...............putt..putt.. dies. cannot get it to go faster that 35 mph. when it will run. any ideas??
Old Dec 19, 2005 | 12:10 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
Try testing the tps and check fuel filter
Can you rev the idel real hi in neutral or park??
Old Dec 19, 2005 | 10:22 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
clogged cat possibly. Bad IAC/Passageways too.
Old Dec 19, 2005 | 10:54 AM
umpire's Avatar
yes... it can rev real high in park
Old Dec 19, 2005 | 11:52 PM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
have you let the car warm up when parked before trying to put it in gear?
Check rotor and cap, timing. I've learned this the hard way, those things can totally screw with your car. By that I mean those thing caused problems that I (and quite a few other people) was leaning closer to a fuel issue rather than a spark issue.
Old Dec 20, 2005 | 12:01 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
check the mass airflow look at the inside elements if they look dirty you can try cleaning them but i never had any luck at cleaning them
Old Dec 20, 2005 | 12:31 AM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
if the maf is suspect just unplug it and drive around like that. it will throw a code, but the ecm just reverts to default fuel tables to run the engine. far from ideal, but it will support a lot more than 35 mph.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
