Need advice on work
Old Dec 21, 2005 | 02:30 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Need advice on work
I need to change the gasket that surronds the water ports on the front of the engine block behind the water pump right above the timing cover. I bought the gaskets at auto zone and its like a hose shoe shape that also came with a water pump gasket. Do I need to take off the vibration damper? It looks like I may not have to but I wanted to know if anyone has done this before and did they have to remove the vibration damper?
Old Dec 21, 2005 | 03:52 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Yes, you have to remove the harmonic balancer to remove the timing cover. This is also a good time to grab a front main seal.
Old Dec 21, 2005 | 08:01 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
I have that with the set also. According to the haynes manuel, It does not look like I have to move the timing cover just to put the gasket around the block where the water port is. Am I missing something? Im talking about the part you take off where the water pump is connected. If you have a pic can you post it.
Old Dec 22, 2005 | 12:13 AM
The_Raven's Avatar
To remove the timing cover, the part behind the water pump, that the water pump is bolted to, you need to remove the harmonic balancer, no way around it.
Old Dec 22, 2005 | 11:34 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
Is the harmonic balancer hard to remove? I never used the damper. Does anyone have instructions how to use it? It seems simple Im not sure. Is there a special way that its suppose to be removed or reinstalled?
Old Dec 22, 2005 | 12:16 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
You must use a harmonicbalancer puller. If you try to remove it with a jaws-style puller, you'll in all liklihood ruin the damper. I got mine for like $25 @ AutoZone. I think on the 2.8L, you may not have to remove the cover.
Old Dec 22, 2005 | 12:25 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Don't think you'll have to remove it, but you can get the installer and remover tool from autozone through their loan program. I've changed the water pump on the 3.4 without touching the damper, maybe yours is different. Just didn't want you to buy the tools, whether you need them or not.
Old Dec 22, 2005 | 01:02 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Do be careful because if the 2.8 is like the 3.4, then you may ruin the timing cover gasket if you do not fashion a special retaining tool when removing the water pump. The Haynes book explains it. Check AutoZone's web site -- a lot of the Haynes bok info is publicly available. It
Old Dec 22, 2005 | 04:43 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
On the 2.8 you do not have to remove the balancer to remove the pump. However, I am talking about the part that is connected to the engine block to get to the timing cover not the timing cover its self. The part that I am talking about may be called the front cover unless the front cover is another name used for timing cover. My question is, Do I have to use a damper tool to remove the water pump peice that connects to the engine block not the water pump its self, Im talking about The peice after you remove the water pump.
Old Dec 22, 2005 | 05:44 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
i have changed my water pump and disected another identical engine and it has the waterpump then the timing cover which has the water channels in it for the pump. and the only thing i saw int the way of the timing cover removal was the belt pulley and the ballancer.
http://www.gmgoodwrench.com/perfpart...f/12363230.pdf
is it on that engine?
the 2.8 and 3.4 are bolt for bolt identical so if its on yours it should be on there.
Old Dec 22, 2005 | 08:06 PM
The_Raven's Avatar
front cover = timing cover.
Yes you need a puller made for removing the harmonic balancer.
You can buy a cheap one for about $20, at most auto parts stores. Some stores also have a loan a tool program as well.
xkingcodex
Feb 12, 2020 07:43 PM
justin57
Aug 20, 2015 07:05 PM
Dan's 83z28
Exterior Parts Wanted
Aug 20, 2015 02:16 AM
jharrison5
Aug 19, 2015 05:53 PM
Newguy91rs
Aug 7, 2015 09:51 PM
