Car Starts Then Stops
Old Dec 18, 2005 | 12:34 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
I DRIVE A 1990 CAMARO RS V6 3.1 AND IT STARTS THEN STOPS UNLESS I KEEP MY FOOT ON THE GAS I CHECKED THE ALTERNATER LIKE MY MANUALE SAID IT STILL DOES IT.I JUST GOT MY LEARNERS PERMIT AND WOULD LIKE TO DRIVE MY CAR, ANY HELP WOULD BE GREATLY APPRITIATED.
Old Dec 18, 2005 | 12:37 AM
Doom Sayer's Avatar
Car: '06 Nissan Sentra SE-R Spec V
Engine: Big block 2.5L
Transmission: 6 Speed
I kinda had a problem like that a while ago... It stopped doing it so I never bothered to check to see what it was. A couple of guys said it might be the IAC (Idle Air Control) so check that.... Check mine while you're at it...
Old Dec 18, 2005 | 12:49 AM
Car: CAMARO RS
THANKS I HAD A CODE ABOUT THAT RECENTLY BUT NEVER REPLACED IT IF I REPLACE IT I'LL TELL YOU IF IT WORKS
Old Dec 18, 2005 | 02:12 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
I know this is probably the most generic answer you could get but my car started doing the same thing a while back and i checked all the vacume lines like they all say to and shure enough had a cracked one replaced it and the car has yet to do it again. Its not that hard to imagine that considering that nearly EVERYTHING on these cars is controled by the vacuum(is that how you spell that?) lines including the IAC so if there is a vac leak it won't work right if at all. Also you dont have to type in all caps to get attention.
Old Dec 23, 2005 | 07:01 PM
Car: CAMARO RS
thanks it worked
I took out the iac valve and cleaned and it started right up thanks you have helped me greatly all my vacume hoses have been replaced within the last few months so i knew it wasn't that and sorry about the caps
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
