where's the fuel filter
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you are under the rear of the car by the rear wheel you will see four hoses coming from the tanks (three by the filter as one ends with a vent) it is the shiny cylinder looking thing. i have always found it easy to change. but you will probably dump some gas on yourself.
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I wasnt even thinking when I did mine and splashed all over me.
Hmmm...Fuel line contains fuel??
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
fuel filter
Im about to change mine but the lines are rusted and they just bend when i try to unscrew them what should i do? Soak it with pb blaster?
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Yes soak it good, and let it sit overnight. Also Tomp has a number of posts on how to change the fuel filter without breaking the lines or stripping the fittings.
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
