Pass Side valve cover to air intake pipe
Old Jan 23, 2006 | 10:08 PM
dcm01003's Avatar
Car: Black 89 Camaro RS w/t-tops
Engine: 2.8L (173ci) v6
Just a quick question to see what people did with the pipe that connects from the passenger side valve cover to the air intake tubing when they replaced the stock air intake completely or just the tubing. I have thought about replacing it with a breather (easiest) or somehow drilling and installing a connection to the pvc tubing that I have used to replace the stock tubing.
Let me know your thoughts/experiences.
Thanks,
Dave
Old Jan 23, 2006 | 10:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I just use a breather and plug the TB
Old Jan 24, 2006 | 09:38 AM
dcm01003's Avatar
i am a little confused as to what you are refering to, the pipe doesnt connect to the TB, it connects to the air intake tubing going to the TB. For the breather, what brand/type/size did you use?
Dave
Old Jan 24, 2006 | 12:46 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
He is talking about a V8 but just do the same and plug the vacume line.
Old Jan 24, 2006 | 05:12 PM
dcm01003's Avatar
gotcha, thanks
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
wruiz
Aug 11, 2015 02:59 PM
mustangman65_79
Aug 8, 2015 01:18 AM
