Free idea
Old Jan 22, 2006 | 02:53 PM
wizman073's Avatar
Car: 1987 Firebird
Engine: LB8, 2.8L V6
Transmission: t-5
Free idea
What if I were to put a hole in the lines that come off the PCVs and plug them so that none of the stuff coming out would end up going through the intake again. If I did it right, I could make it look like everything still works, aka pass a visual. Would I suceed in lowering intake temps/increasing power any?
Old Jan 22, 2006 | 04:40 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Re: Free idea
No, you would do quite the opposite.
Old Jan 22, 2006 | 04:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If you live in a smog check zone don't bother. But the PVC system does dumb some nast crap into your intake. Had mine off once and was shocked at all the crude in the sucker.
Took bunch of funky shaped brushes n chemicals to get it clean.
Since I am in a smog free zone first thing I did was a PVC fresh air mod. PVC dumps into a fancy little blue filter and not my intake anymore.
Old Jan 22, 2006 | 08:31 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
is there just any pcv filter i can use or do you have a particular part number gumby? ive been wanting to ditch mine for a lil while now for the same reason, just never got around to looking up the numbers. where did you get yours?
Old Jan 22, 2006 | 11:41 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Actually I forget which catalog I got it from. But I did get robbed in a way. Pic made the filter look 30x its size in catalog. Didn't think it was hugh but not so small. But it came in handy. Used it for a while as a cankcase vent on a motorcycle then on the car.
Basically same thing as when V8 guys put them filter in the valve cover. Lets the top end gasses n junk vent free. The filter keep the engine from sucking in dirt.
Old Jan 24, 2006 | 01:14 PM
wizman073's Avatar
Car: 1987 Firebird
Transmission: t-5
Gumby, if you can remember anything about where you got the filter, or even what its called/ what size it is, that would be awesome. Does it slip right on? if so, even though I dont think it would be legal, Ill just take it off when I go to get it inspected. Thanks
Old Jan 24, 2006 | 01:35 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
they sell that filter at autozone...
Old Jan 24, 2006 | 02:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I don't remember crap and yes it didn't fit but was easily made to fit.
Used the tip off a small cheap funnel. You can see it there in the pic, its red.
siliconed one end to filter and hose thingy slipped n pop right in.
Might wanna ge two. One for each hole. One for the PVC tube and one for the hole in the intake hose.
Old Jan 24, 2006 | 06:41 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
If you want to stay smog legal just install a small catch can in the PCV line between the PCV valve and the intake. You can pick up one of those Campbell/Hausfield water seperators used in air compressor applications to collect the oil, then just unscrew it and dump it every so often. You can do it for about $20~$30 and 15 minutes of your time.
Or, you can do like the guy at this link (http://www.neonrick.com/oilair_howto.html) did and splice in a collector with a petcock at the bottom for draining.
Old Jan 24, 2006 | 06:45 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Never mind.
Frozer!!!
Jan 19, 2024 04:55 PM
beastin91rs
Oct 9, 2015 07:38 AM
lt1z350
Sep 29, 2015 01:50 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
backtothe80s
Sep 5, 2015 12:39 AM
