3.4 swap distributor Q's
Old Feb 8, 2006 | 12:07 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
when swapping in my dizzy into the 3.4, is that all i need to put in. do i need my old oil pump shaft or anything else, im putting it in with the replacement O ring and a SBC dizzy gasket
Old Feb 8, 2006 | 12:33 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
i reused my oil pump shaft since it was stuck in the end of the distributor. but you can use the one out of the 3.4. its the same setup as the 2.8/3.1.
Old Feb 8, 2006 | 01:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
shaft is the same, hold down clap is same.
Just need the new o-ring.
remember, if you can post all 3.4 swap questions in my one massive thread that way its all together in one place for future swappers and searching.
Old Feb 8, 2006 | 07:36 PM
Car: 1986 Firebird
only reason i asked is because i know the 95 firebird im getting the motor from has DIS...right?, i was just a little unsure of what exactly was driving the oil pump since that shaft is driven by the dizzy in my 2.8
midge54
Jan 29, 2017 07:00 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
92projectcamaro
Aug 6, 2015 01:20 PM
