car problems
Old Feb 11, 2006 | 03:31 PM
camaro1fan's Avatar
Car: 1990 RS
car problems
hello, i have searched for this and didnt find anything. i have a 90 3.1 camaro, i have a problem with it. is starts but dies, it's at the shop, the checked and it has 40 psi fuel pressure, spark is good, they did a full service tune up, needed it anyways. alternator, starter, and everything else is good. they are baffled. like i said car turns over but dies.
Old Feb 12, 2006 | 12:26 AM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
Did they check for good airflow? My car used to die if I didnt rev the motor up to 2k for a few first thing in the morning (never any other time) After I cleaned the throttle body havent had the issue since. Your car giving any codes? Does it die like the fuel got cut off (sputters off)? or like the battery died (just a straight cutoff)? There's so many factors that can cause it.
Old Feb 17, 2006 | 01:04 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Two of my Camaros had mysterious stalling and dying problems that were difficult to diagnose. Both turned out to be caused by clogged catalitic converters.
Old Feb 17, 2006 | 09:13 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Yes sir, took the words right out of my mouth.
sawzall+$15 worth of autozone pipe and clamps=
Max
Old Feb 17, 2006 | 06:01 PM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
I did mine the caveman way - hacksaw and tin snips for the last bit. Tubo de escapo for the win!
Old Feb 25, 2006 | 11:29 PM
RSFreak's Avatar
Max
Hells Yeah! The CAT on my '84 was so clogged that it would idle but would die as soon as I gave it some gas. I noticed a hissing sound coming from the CAT and discovered that exhaust was trying to escape from a tiny pin hole in the CAT! I sawzalled a chunk out of the 'Y' pipe and headed off to work!
Ghettobird52
Jul 5, 2024 11:18 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
