squeaking
Old Feb 14, 2006 | 06:30 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
squeaking
Well when its cold in the morning on or cold at night the car will squeak loud as **** and when i accelerate it keeps squeaking louder. The belt is brand new pretty much less then a 1000 miles on it i changed it when i got the underdrive crank pulley and i sprayed belt dressing on it even tho the belt was fine and i figured it wasnt the belt. Any idea on what the hell is making this noise? My autotech teacher said it could be my water pump but my engine temp is normal.
Old Feb 14, 2006 | 07:22 PM
89TXThirdGen's Avatar
Car: 89 Camaro
Engine: 2.8 MPFI
i'm not sure what the problem is but mine does sort of the same thing and i couldn't figure it out.
Old Feb 14, 2006 | 07:26 PM
daves12secV6's Avatar
check the bearing in the alternator
Old Feb 15, 2006 | 12:35 AM
Spazz698's Avatar
Car: 88 Camaro, 93 civic hatch
Engine: 2.8L, 1.5L VTec
Transmission: 5 Speed, 5 Speed
check to make sure all the accessory pulleys arent difficult to turn. I was having a squealing problem for a while, pulled the belt off and checked everything just to find out nothing was wrong and the belt was damn near new. Figured out it was the massive amount of rain causing it (I have a nice lil hole in my hood, not close to the belt but apparently close enough for a month straight of rain to mess with it but not 1-2 days of rain to)
Old Feb 19, 2006 | 08:32 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
check the tensioner, it may be wearing out and close to the end, causing not enough tension on the belt. also, belt dressing is a bad thing. once you find out whats causing the noise, fix it, get a new belt and take a wire brush to each pulley and get that crap off of there. belt dressing is a bandaid, and a crappy one at that. if you ever have that problem again, try silicone spray or vaseline on the belt, that will quiet it down for a lil bit.
Old Feb 21, 2006 | 06:55 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
squeaking
its not the belt, but it only squeaks in the cold and it doesnt squeak nearly as much with the heater on. I heard it could be a a/c compresser bearing?
Old Feb 21, 2006 | 08:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
could be your speedo cable, it will squeak like mad.
Then sometime it wont.
http://viragotech.com/buickthunder/f...ghlight=oiling
Old Feb 28, 2006 | 07:18 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
squeaking
The mechanic i took it to said that i need a shorter belt like a half inch anybody heard of this. BTW it has the underdrive pulley from asp i got the belt that they recommened anybody else have this problem?
Old Feb 28, 2006 | 07:24 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Re: squeaking
Half inch? The tensioner should EASILY take that... Do they even make belts in half inch increments? I doubt it..
Old Feb 28, 2006 | 07:35 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
belt
actually i need a belt half an inch shorter then the one i got because there isnt enough tension.
Old Feb 28, 2006 | 07:36 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Re: belt
Good luck finding a belt a half inch smaller..
Old Feb 28, 2006 | 08:27 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
maybe his belt is several inches short, and the tensioner is taking up all but 1/2" of that?
Old Mar 1, 2006 | 06:13 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
belt
i got the car back from the shop today because it was in there for a speed sensor the guy broke when he was installing my tranny and he fixed the squeaking by buying a belt that was a half inch shorter then the one i had on there.
Old Mar 2, 2006 | 06:23 PM
drdave88's Avatar
Engine: 6.0L
yes you can get belts in 1/2" increments. usually, the part number on the belt has the last 3 digits as the size. like the last 3 being 795 is 79.5 inches. thats how i found my belt.
elevario
Mar 1, 2002 12:10 PM
elevario
Aug 9, 2001 01:42 AM
crazeinc
Jul 30, 2001 11:58 PM
TomP
Jul 15, 2001 06:43 PM
zedder 1 9 9 0
May 16, 2001 07:20 AM
