So we have polyurethane motor mount inserts now :D
Old Feb 16, 2006 | 09:07 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
ES # 3.1145G for black, or 3.1145R for red.
http://www.suspension.com/g_m_trk_2wd.htm
It lists it as the V6 clamshell - $33/apiece - I'll be ordering two
Old Feb 16, 2006 | 09:14 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Now all they have to make is a poly replacment for the hydraulic manual trans mount.
When mine went bad, I took an auto poly mount and a peice of aluminum and made an adapter that allows me to use the auto mount. It's not perfect and I had to shim the crossmember down to fit, but it works.
Old Feb 16, 2006 | 10:00 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have one in mine
Good deal on the clam mounts. After I got my new engine in and have no plans of taking it out
Old Feb 16, 2006 | 10:04 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Originally posted by Dale
I have one in mine
Where'd you get it, I've been looking for the replacment for the manual trans one, but found it no where.
Old Feb 16, 2006 | 11:27 AM
Dale's Avatar
Engine: 350 S-TPI
I have the automatic one, on a manual. No special brackets, no custom anything. It bolted right up and "presto" it fit, works n all that good shizzle.
Old Feb 16, 2006 | 03:40 PM
Doward's Avatar
Same here... automatic crossmember + automatic poly mount FTW!
Old Feb 16, 2006 | 04:00 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
I had to shim my crossmember down 1/4" and make an aluminum brace for it. I think the reason I had to shim down is because I have the brace above the crossmember, that way I don't have to worry about it bending under load as much. I'll see if I can get my car into the air here at work today or tomorrow and take a picture so you guys can see what I'm talking about.
Old Feb 16, 2006 | 07:14 PM
Doward's Avatar
I had the same mount you do... has the 2 rubber 'bushings' with a 2nd bar on top of the first....
Just pitch that thing as far as you can, and get one of the automatic crossmembers. I paid like $5 at the junkyard for it!
Old Feb 16, 2006 | 08:23 PM
Dale's Avatar
Engine: 350 S-TPI
I started out with the double auto bar.
Ended up converting to spohn bar for my tq arm.
Old Feb 17, 2006 | 12:08 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
the auto x-member is definitly the way to go from what I hear. I'm just too lazy to actually go to the yard to get one...lol
Old Feb 18, 2006 | 10:47 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
that sounds like what my car has and its an auto...
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
