3rd gen/s-10/fiero pulley question//pls help
Old Mar 2, 2006 | 06:57 PM
stocker85's Avatar
i posted a few days ago looking for underdrive pulleys for earlier 2.8's with no replies,,,,,,,,,i am trying to figure out what year s-10's/fieros are compatible,,,,,,,,,,,,I am looking for a pulley for an 1986 2.8 ,,i found this company
question is which one do i get/what year fieros/s-10 have the same pulley as my 86,,,,,, thanks
gm truck pulley 1
http://www.streetbeatcustoms.com/asp541800.html
gm truck pulley 2
http://www.streetbeatcustoms.com/asp546700.html
fiero pulley
http://www.streetbeatcustoms.com/asp845200.html
Old Mar 2, 2006 | 10:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I am quite sure the fiero pully is different, I got a wrong one from jet and it was found to be fiero.
s10/camaro do interchange.
Unless your going for bling bling factor, I would go with ASPracing.com and get one... I have had some bad CS with streatbeat before as well as jet.
Old Mar 3, 2006 | 09:10 AM
stocker85's Avatar
cool thanks,,,,,,,so just to be sure,,,get the 85-86 truck pulley?,,,or the 87 and up,,,,,i know s-10s were a bit behind tech wise compared to the 3rd gens (ref no mpfi vs. tbi)
Old Mar 3, 2006 | 09:57 AM
Dale's Avatar
Engine: 350 S-TPI
actually, is that car of yours a vbelt setup, or serp?
Actually, the TBI system is more torqy along with a different cam and thus the reason they used it in the trucks. Otherwise, as for as engine updates, wiring, elec speedo n all that, it kept up.
Old Mar 3, 2006 | 10:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
do believe most times this comes up, those who have done it say just do the crank pully and leave the rest alone.
Old Mar 3, 2006 | 11:47 AM
stocker85's Avatar
got the factory mixed setup,,,,
Attached Thumbnails 3rd gen/s-10/fiero pulley question//pls help-pulley.jpg
Old Mar 3, 2006 | 12:16 PM
Dale's Avatar
Engine: 350 S-TPI
WTF???
I have never ever seen that setup. I dont know what you need.
Old Mar 4, 2006 | 09:04 AM
stocker85's Avatar
haaa gotta love transition times with cars,,,,,,,guess when spring comes,,,,i'll have to buy one and try it,,,
Old Mar 4, 2006 | 09:27 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Yep same as My S-10 when I first got it.
Old Mar 4, 2006 | 07:59 PM
stocker85's Avatar
raven............what year s-10 was it?????????????
Old Mar 4, 2006 | 08:33 PM
The_Raven's Avatar
'85
Old Mar 5, 2006 | 11:49 AM
stocker85's Avatar
guess the sticky needs to be updated ref underdrive pulley,,,,serp and pre serp pulleys so this doesnt come up again,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,whenever i get the pulley and put it on i'll update
Old Mar 5, 2006 | 09:24 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
My 2.8 has a serpentine belt and a v belt, i dont use the v belt but it there on the pulley. ??????????????????? of course it also only has the air injection on the driverside exh. manifold. so who knows?
Old Mar 13, 2006 | 04:50 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i have hpertech's pulleys for the 60 degree V60
used on her 90 FB 3.1l
https://www.thirdgen.org/forums/show...hreadid=351379
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
