cold start help
Old Mar 12, 2006 | 01:04 PM
blksiryder's Avatar
Car: 1992 camaro rs
Engine: 3.1
cold start help
92 rs starts up just fine. but won't stay started. when it stays started. it stalls in gear. when it warms up a little fine in gear till you push the gas then just spits sputters and backfires a few times then runs just fine. if i hit a stop light same thing till the eng heats up so about 15min on avg. it thetre a eletronic choke on the 92 3.1 v6? no vac leaks at all just a real low idle. can any one help me with this.
matt
Old Mar 20, 2006 | 05:41 AM
cmro92_rs305's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: Auto.
Well, I'm not sure, but my 2.8 in my Fiero has a cold start injector. If your 3.1 has it, it is most likely bad. Just my .02
Old Mar 20, 2006 | 09:50 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
2.8s have a CSI, but not the 3.1s. Chack to make sure that the IAC passages are clean and that the minimum air rate is set correctly. One thing that you can do is to have someone turn the key on when it's cold and you put your hand on the IAC motor. If it doesn't feel like it's vibrating a little, it's not working and should be replaced.
A lot of the time the IAC motors fail when cold because they need to open way up for cold idle but can't amke it that far, but once the car si warm, they act just fine because they don't have to mive as much.
Old Mar 20, 2006 | 03:41 PM
blksiryder's Avatar
Car: 1992 camaro rs
Engine: 3.1
thats was it man!! thank you now it runs like a champ. now all i need to do is find some power adders
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
