got it running but not for long?
Old Mar 19, 2006 | 08:46 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I got my 2.8 running after changing the Head Gaskets. I finally figured out that the #1 cyl is on the left side, unlike a v8. I got it running setting TDC on #2 but it ran bad. I set #1 to TDC and started it up. Low idle and the motor shook. I let it run for a while and it cleared up a bit but it wouldn't hardly idel. I would have to help it stay running sometimes. I could smell that the gas was bad, possibly water in the tank. I bought this car not knowing how long the car had set with gas in it. I siphoned the gas out and put in fuel injector cleaner and some high octane in what gas was left in the tank and it ran a little better. I drove it up and down the road and then parked it, shut if off and tried to start it back up and nothing. I am having to wait until the next day to try and start it back up.
what can I try to remedy this? I don't have a lot of money to try parts and them not to work, can't afford a mechanic either. So I'll take whatever you guys throw at me.
I read in another post that a guy tried everything and he finally replaced the ecu and that was the problem, is that the computer? If I do need to replace it does anyone have one of these?
Old Mar 19, 2006 | 08:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
#1 is on the right side, UNLIKE a v8 Set it to TDC.
You need to set timing with the EST disconnected.
Also, if you need a picture of how the dizzy sits in, I can EASLY get one right now with my motor all taken apart as well.
Old Mar 19, 2006 | 09:00 PM
micali's Avatar
Engine: 2.8
if you face the motor the #1 is on the left side. I downloaded a pic from a webpage that told me that. http://autozone.com/servlet/UiBroker...3d80194f35.jsp
sure I could use a pic.
Old Mar 19, 2006 | 09:35 PM
Dale's Avatar
Engine: 350 S-TPI
oo, ok, yes, if your looking at it that way.
Will get you pic tommorow once its daylight and I restab it
Old Mar 19, 2006 | 09:43 PM
micali's Avatar
Engine: 2.8
can you add in the pic where the est is?
Old Mar 19, 2006 | 09:54 PM
Dale's Avatar
Engine: 350 S-TPI
aye aye captin.
Old Mar 19, 2006 | 10:16 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
First off, the EST is on the Passenger side coming out of the loom attached to the firewall. I just went out and took some pictures for you, so I'll attach them. As you can see, it's on the left had side as you are facing the engine from the from tof the car, right above the blower box on the cowl. Start the engine and disconnect it, then set the timing to 10* BTDC. Tighen the clamp, then check it again before reconnecting the connector. As long as it's still at 10*, then shut off the engine, reconnect the EST and restart. It should be MUCH happier than before.
Do this, and if it still runs like crap, let us know.
Hope this helps,
Jeff
Attached Thumbnails got it running but not for long?-dscf0159.jpg   got it running but not for long?-dscf0160.jpg
Old Mar 20, 2006 | 05:38 AM
Dale's Avatar
Engine: 350 S-TPI
Good job 2.8. However, thats not where mine is, LOL. Thats the connector though.
Old Mar 20, 2006 | 09:45 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Take a picture and post it. On all of the 3rd gens I've smogged over the years, I've never seen one that wasn't there. I'd like to see it, that way I know for future reference.
Old Mar 20, 2006 | 05:17 PM
Dale's Avatar
Engine: 350 S-TPI
Ok, heres the pics
Attached Thumbnails got it running but not for long?-img_1628-600.jpg   got it running but not for long?-img_1630-400.jpg
Old Mar 20, 2006 | 08:09 PM
micali's Avatar
Engine: 2.8
wow, your rotor bug is pointing more towards the middle of the motor. Mine is more towards the left. I was told that I can choose any point on the dis. and make it number 1 and then go from there, is that true? Since it goes 123456 on the cap.
if you look at the dis, in the pic, do you see the screw hole in the dis? My rotor points to the next terminal. on the cap. past that screw hole. Is that ok?
Old Mar 20, 2006 | 08:37 PM
Dale's Avatar
Engine: 350 S-TPI
I was "told" it doesnt work like that. Where you can stab the dizzy in anyway, and rotate it to match. However, I dont see why it cant/doesnt/wouldnt.
But the way mine is, is the only way I've gotten it to work... on my setup
Can someone else verify that theres looks to be positioned about the way mine is?
Old Mar 20, 2006 | 08:46 PM
micali's Avatar
Engine: 2.8
dale is yours a 3.1? so where the rotor bug is pointing is that were the #1 is on your cap?
Old Mar 20, 2006 | 08:58 PM
Dale's Avatar
Engine: 350 S-TPI
it was a 3.1, its now a 3.4. but it doesnt mater.
Yes, thats where #1 is on my cap
Old Mar 20, 2006 | 09:42 PM
micali's Avatar
Engine: 2.8
I'm still having troubles. So the way you have the dizzy right now in the pic, is that how you stabbed it in the motor? so can you tell me from the screw on the cap which terminal is #1 for you? I have a pic of mine but I can't attach it.
Old Mar 21, 2006 | 05:42 AM
Dale's Avatar
Engine: 350 S-TPI
I'll take a pic of the cap tonight.
Old Mar 21, 2006 | 06:32 PM
micali's Avatar
Engine: 2.8
thank you!
Old Mar 21, 2006 | 07:31 PM
Dale's Avatar
Engine: 350 S-TPI
Old Mar 21, 2006 | 07:59 PM
micali's Avatar
Engine: 2.8
thanks, I'll redo mine when the weather warms up. I hope this works. if the lifters were to tight how might the motor run?
Old Mar 21, 2006 | 08:32 PM
Dale's Avatar
Engine: 350 S-TPI
lifters to tight, it wouldnt get compression, and I belive it would backfire. Vac reading would be all wack too.
Dont feel bad, I got mine partly running tonight in this cold *** weather... to find I have a massive oil leak.
Old Mar 21, 2006 | 09:23 PM
micali's Avatar
Engine: 2.8
Hey, I checked out your site. Nice pics. I am wanting to get into this. I just can't afford the cannon 20D yet. I have a graphics design degree and I love photoshop. enough about that.
How can I upload pics?
Old Mar 22, 2006 | 08:34 PM
micali's Avatar
Engine: 2.8
Dale, check this post of mine out. This is how I have my dizzy. my rotor is pointing more in between 3 and 5. I restab it this weekend. Nicer weather coming up.
the post is "please help. anyone with a 2.8"
Old Mar 23, 2006 | 08:06 AM
82-T/A [Work]'s Avatar
If it's not starting after the car warms up and you shut it off... it could be a bad starter. Fiero owners have this happen to them all them time when they replace the starter with cheap replacements.
Old Mar 23, 2006 | 04:43 PM
micali's Avatar
Engine: 2.8
I am not so sure it's the starter. The car will crank over but will not fire, like it is getting no spark.
Old Mar 23, 2006 | 10:24 PM
Ok... I know what the problem is now. If the car doesn't start after it's warmed up, and it runs like ***... the problem is the ignition control module. It sits under the distributor cap.
Sometimes they fail immediately and you can't start your car... othertimes they fail slowly where the car runs poorly but won't start after it's warmed it.
They're about $30-$50 bucks.
Get an original AC Delco or a Bosch.
Trust me, that's your problem...
Old Mar 23, 2006 | 11:11 PM
micali's Avatar
Engine: 2.8
this might be the case. I'll look into this.
Old Mar 24, 2006 | 03:40 PM
micali's Avatar
Engine: 2.8
this is where I have my timing set at and dale if you look at your pic, I notice that the flat edge next to where the ICM sits, yours is turned more. Mine is more parallel with the engine, when I stabbed it. Should I go straight in like mine or have it turned more like yours when it goes into the motor or does it matter? My rotor isn't pointing in the same dircetion as yours. I can't get mine to go that straight. It's either one way or the other but not straight. I am about ready to part this thing out.
I know about v8's but this little crap of a motor is about to make me pull my hair out.
Old Mar 24, 2006 | 03:44 PM
micali's Avatar
Engine: 2.8
I hope this pic loaded
to big don't open
Old Mar 24, 2006 | 03:58 PM
micali's Avatar
Engine: 2.8
look
Old Mar 24, 2006 | 04:01 PM
micali's Avatar
Engine: 2.8
timing
Old Mar 24, 2006 | 04:32 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Now, do you have 3 cuts in the balancer like I do? I have one that is painted bright white and the other 2 are just unpainted. Make sure that you have it on the right one.
There are 3 cuts so that you can check timing on individual cyinders.
Old Mar 24, 2006 | 04:50 PM
micali's Avatar
Engine: 2.8
I have 3 and none are painted. one is just a larger groove then the others. I think I am on the right one. But for the life of me I can't seem to figure out this D@mn dizzy.
Old Mar 24, 2006 | 04:55 PM
Dale's Avatar
Engine: 350 S-TPI
yea, that looks about like mine.
I have a large camera, so its hard to get a strait down shot.
Old Mar 24, 2006 | 05:39 PM
micali's Avatar
Engine: 2.8
how do you pm anymore? I would like to personally talk to dale or 2.8boy. It might be easier to get my point across that way. My email is hot_rod_chevy56@yahoo.com
Old Mar 24, 2006 | 09:22 PM
Dale's Avatar
Engine: 350 S-TPI
email sent
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
