catco cats for 2.8
catco cats for 2.8
Have any of you guys gone with a catco cat on you 2.8? If so, how do you like it, any difference (they are high flow, are they not)? Does it change the sound any?
thanks.
thanks.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i had one for a while. best 30$ i ever spent.
as far as "high flow" goes, i was reading somthing recently that said that high flow is a gimick. they all pretty much flow the same. anything you buy off the shelf will outflow the stocker by leaps and bounds. thats why i always thought a "cat-delete" ona 2.8L engine was silly.
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Yeah, as far as High flow goes, it doesn't matter on our cars. Any Honeycomb style cat will outflow 400hp, and I'll be shocked when Doward hits that mark with 30psi...lol.
Anyway, they aren't known for their longetivity when it comes to getting you past smog in 4 years, but if all you're looking for is a "right now" cat, it'll be fine. They're cheap for a reason.
Originally Posted by 2_point8_boy
Hey, that's something I said...lol
DynoMax, MagnaFlow and CarSound are three of the best and most reliable.
Car: 1988 Camaro RS
Axle/Gears: 3.42's
hmmmm, cuz 2 of those anyway are the same price or cheaper than catco. And magnaflow is actually carsound I do believe (made by them).
Then I guess it's up to you which one you go with. I'm just stating that as a Smog Tech in California, that's what I've seen.
I will have to maybe consider one of the others then if the price is similar. I will have to recheck prices.thanks.
Axle/Gears: n/a
i passed smog with my catco, 30K and 2 years later i passed again. however "cheap for a reason" sounds like sound logic to me, if magnaflow or carsound is the same price deffinatly go with one of the better brands.
EDIT and thats with no air injection hooked up. well the pump and manifold connections are all still there, just not connected to the cat.
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
Yeah I just confirmed, at summit the magnaflow is actually cheaper than the catco.
Anyone know if there is a dynomax direct fit for the 2.8? I have not been able to find one yet.
Here is the link for the dyanomax direct fit cats. You have to scroll to the bottom of the page for the info.
JEGS High Performance - Dynomax Super Converter
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Nothing listed there for the 2.8, only 5L
Actually called jegs and ordered one yesterday and verified that it is the correct one for 6s also. Its just a direct fit for our camaros v8 or not. Its just listed that way on the site. If ur not sure call yourself and verify first just like I did.
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Oh ok, didn't realize it was a typo.....good to know! Which part # are you referring to?
The one on the very bottom of the spread
289-15735
So will only changing a cat (to a higher flow one) change the sound of the car at all or is that primarily the muffler?? Sound is not my goal with this, I just need to change the cat and got curious.
LT1Formula
Oct 8, 2015 08:34 PM
