header bolts
Old Apr 6, 2006 | 10:47 PM
redbird8628's Avatar
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
header bolts
I was not aware the pacesetter headers do not come with bolts, with the stock manifold boltswork, or are they too long? also, is 1200* exhuast paint in many clean layers enough to fight rust and paint burn off?
Old Apr 7, 2006 | 05:47 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
they do come with bolts. If they didnt, you need to contact them and bitch.
Old Apr 7, 2006 | 04:18 PM
Car: 1986 Firebird
well, only reason i asked was that both summit and jegs specify that the do not come with bolts, but the picture of the kit clearly has them
Old Apr 7, 2006 | 06:00 PM
Dale's Avatar
Engine: 350 S-TPI
mine came with them. Id contact both and ask WTF is up.
Old Apr 7, 2006 | 08:53 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
mine didnt come w/ bolts either. i ended up buying the grade 8 locking header bolts, or whatever theyre called. the gaskets that came with the pacesetters sucked, they blew out in a few months so i got the felpro gaskets.
Old Apr 7, 2006 | 09:50 PM
Car: 1986 Firebird
yea, i have some metalish napa gaskets sitting around doing nothing, would sbc header bolts fit, or would i nead a special order, if you remember, what kind did you use?
Old Apr 8, 2006 | 09:41 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
just take your old bolts to the hardware store or rural king(old mainifold bolts)....find some with the same thread, pick a length, add lock washers and yoru done, its not all that difficlut, cost me $1.37 for the bolts...(oh and maybe some lock tight just incase)
Old Apr 8, 2006 | 09:55 PM
Car: 1986 Firebird
i gotcha!
Old Aug 27, 2006 | 08:23 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
Funny, on PaceSetter's website it says that their headers do not include header bolts.
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
