ECM problem..help
Old Apr 11, 2006 | 01:02 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
ECM problem..help
I have a 91 3.1 with 158k.Very rough idle.The problem im having is the ECM will not turn on my fan, even at 250 degrees no fan.
I can run fan by grounding dk green wire at relay.
also ,no code is set when i unplug the DST when i set timing.
My question is, can parts of the ecm fail while having fair drivibility.
no codes are present..
Old Apr 11, 2006 | 01:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
the helms owners manual says yes.
I would first check/replace the CTS and see what that does.
Old Apr 11, 2006 | 07:05 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
does the A/C work? If you turn it on and the fan comes on, the trouble isn't in the ECM. My guess is that the temp override switch has gone bad.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
