Changed my build...
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Changed my build...
Well Im selling all my 3.1 internals, GN turbo, spare heads ect.. I found a 3.4 5-speed Camaro for 400 bucks that Im gonna buy and swap the drivetrain into my 86'. Picking up a set of FWD heads, intake, rails, injectors and pistons tomorrow to swap onto the 3.4. With the new intake and rails I will be able to use my custom plenum and TPI throttle body with less modifications. I think I can hit 15's with this set up.. Well I still got my intercooler and BOV, plan on using them with this engine.. After I find another TE04H Turbo so I can do a twin setup..
HAHAHAHAHA!!! Opinions are welcome..
HAHAHAHAHA!!! Opinions are welcome.. Supreme Member
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
good on you , mate!! swap over the entire dash too, since you have everything available, use it. trust me on this, use it. It will make this swap sooooooooooo much simpler.
What year is the donor car too?
also, see the other swap on the header/exhasut manifold issue.
86CamaroDan
Sep 29, 2015 10:08 PM
