Timing and EST
Old May 7, 2006 | 05:46 AM
jdk1987's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Timing and EST
I was just about to advance my timing when I kept reading about the EST...? Does it need to be in?.....Out?....What? Thanks...
Old May 7, 2006 | 06:04 AM
michal_larson's Avatar
hook your EST wires (brown/black stripe) together after you time it as that is where it gets its signal from the ECU, 5 volts = full advance. 0 volts = no advance, it needs to be on
Old May 7, 2006 | 07:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To check/set the timing the BYPASS connector needs to be open, or disconnected. Once the timing has been checked/set the engine needs to be turned off and this connector re-connected. The engine may then be re-started.
With the BYPASS (commonly called the EST connector) is open the distributor runs the timing at the base setting. When rev-ed up there will be some advance. With the BYPASS connector connected the ECM controls the timing.
On your '92 the connector is under the hood, passenger side, behind the stut tower. There is a single wire, tan with black stripe, with an inline connector. It comes out of the harness to expose the connector then goes back into the harness.
Set the timing on a warm engine. It will almost stall when the connector is first disconnected. Number 1 plug is passenger side front. It is easier to use # 4, center plug on driver side. Will time the same as using # 1.
If you have an auto trans, do not disconnect the battery to clear the code. Let it clear itself.
RBob.
Old May 7, 2006 | 11:46 PM
dont heckle me dude, im not in da mood.
Old May 7, 2006 | 11:47 PM
yeah what he said, let the code clear itself ....after 50 key turns.
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
What???
Old May 7, 2006 | 11:48 PM
was i talkin to you?
you think this is a game? you think im playin? i help people, thats what i do, thats all i do.
Last edited by michal_larson; May 7, 2006 at 11:50 PM. Reason: Automerged Doublepost
Old May 9, 2006 | 03:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
RBob.
RBob, why's that? Or is that just to prevent the long "re-learning" scenario?
Old May 10, 2006 | 12:22 AM
most bins i looked at clear the codes them selves after 50 key turns. just simpler to disconnect the batt. as for manual or automatic, does not matter.
Old May 10, 2006 | 10:23 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, to prevent the required idle learn.
RBob.
bamaboy0323
Sep 3, 2015 06:07 AM
1992Vortec
Aug 31, 2015 08:05 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
