WOOT, time for the good cam.
Old May 22, 2006 | 08:10 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Well, its been 5 weeks of driving on the truck cam. And I installed a timing chain on a boat motor this weekend giving me exactly enough cash for all the parts I need.
So I have sitting on the garage floor..
MTC-5
Melling lifters
tc gasket set
intake gasket set
Part of my suspension I had ripped out for redoing before the boat ordeal.
I think I know what my memorial day weekend will consist of
Then time for the custom home intake... that I'm still debating on a design.
Old May 22, 2006 | 04:13 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
im glad to hear you didnt have to get rid of it dale, you know youd rather have a v6 anyway, who needs a vert, youre just asking for leaks, lol. im gonna get some tires soon to stick better and we should take a run down the 1/4 mile sometime since we have such similar engine setups
Old May 22, 2006 | 06:25 PM
Dale's Avatar
Engine: 350 S-TPI
OO, I still want a vert, v6 or v8, I dont care. But a vert is in order! We dont get alot of rain here, but when we do, we get it!!
I've never been on a drag track, so if you have, you'd win. I just drive like a maniac on the cornors
I'd like to dyno it, and or track sometime. But next up is an intake design that I will be posting questions on sometime in the near future.
Old May 22, 2006 | 07:00 PM
daves12secV6's Avatar
dale specs on that mtc-5 cam?
im looking for a new cam that will work well with my turbo motor,and i havent looked into that cam yet
Old May 22, 2006 | 07:29 PM
drdave88's Avatar
Engine: 6.0L
Basic Operating RPM Range: 1,000-4,200 RPM
Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 278
Advertised Exhaust Duration: 288
Advertised Duration: 278 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.443 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.443 exh. lift
Lobe Separation (degrees): 110
straight from summits site, doward has said its an amazing cam for a turbo, hes got it and hes running it w/ his turbo. thats what im running as well, didnt notice a huge difference, but it was 5 months between before and after driving so i cant be sure on the results, and the 87 ranger i was driving, anything will be better, lol
oh yeah, hurray, i finally hit 1000 posts, lol
Old May 22, 2006 | 08:04 PM
yeah that does look like a pretty decent cam for a turbo/supercharged motor.
ill have to keep that one in mind.if i cant find something with more lift
Old May 23, 2006 | 10:05 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
It's a great cam for a turbo or supercharged motor - if you're staying N/A, it's a step over stock, but I'd really recommend something in the 212/212 or slightly bigger range
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Linson
Aug 21, 2015 02:12 PM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
