distributer lock bolt 2.8 difficult to access
Old May 28, 2006 | 03:34 PM
tjk62's Avatar
need to adjust timing cannot get to lock down bolt tried socket 9/16 and distributer wrench no luck
Old May 28, 2006 | 04:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
its 15mm
Old May 29, 2006 | 07:52 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
15mm socket, universal and an extension...swearing some helps too...
Old May 29, 2006 | 08:17 PM
Leo_padakin's Avatar
Car: 1985 reliant saloon
Engine: 2.2 pile of metal
Transmission: 3 on the tree
Axle/Gears: so tall theres no point
^^^^ I second that.... swearing deff. helps alot.
Old May 29, 2006 | 08:54 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
About a million years ago when I had a V6 I used a 15mm swivel socket and a 6 inch extension. The socket/swivel combo was a little too tall.
Old May 29, 2006 | 11:33 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I just got an old 15 mm long wrench and heated/bent it about halfway down (2 inches from socket head) to a rough 45/50* angle. Works great.
Otherwise hit up sears (known to have them) for a 15mm "S" wrench.
They are even labled GM HEI access wrench (or something like that)
I save the searing for something actually hard, like V8 Motor mount bolts, or the rear header bolts... or just something that refuses to co operate.
Old May 30, 2006 | 03:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also use a 15mm socket, universal/swivel joint, 7" extension, ratchet handle to get to that bolt.
When I first got the car, I cut a 15mm wrench in half and used the 6 point box end...
One big factor is how the distributor was dropped in. The connectors for the ignition module (going to the base of the distributor) may get in the way.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
deracer
Apr 11, 2016 12:04 AM
db057
Sep 4, 2015 07:57 AM
pimprs
Aug 24, 2015 11:20 PM
