setting valve lash 2.8
Old Jun 5, 2006 | 05:40 PM
micali's Avatar
Car: 1988 sport coupe
Engine: 2.8
Transmission: 700 r4
I am needing to set the valve lash but the car won't start. I think I am close on having the dizzy stabbed correctly. I have the upper intake off and am now ready to get this done. What is the easiest way to do this? I've looked the forums over and that didn't help. So what do you suggest.
Old Jun 6, 2006 | 09:42 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
you dont need the car running to set lash on these. take the valve covers off. start at #1 TDC and set to zero lash (when there is just enough on the pushrod so it wont turn) and then go another 1/2 turn. next is #2, #3, #4, #5, #6. then youre all done and put it back together.
to get the dist in right, go back to #1 TDC, when its seated all the way in, the rotor will be pointing at the #1 on the dist cap, or about 7 o'clock position.
Old Jun 6, 2006 | 10:00 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Search my user name, I typed this strait from the GM manual on here before. It was a long time ago, but I know I did it.
lakeffect2
Aug 23, 2015 08:44 AM
cstrobel65
Aug 15, 2015 10:19 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
