? about a PCV valve problem
Old Jun 7, 2006 | 12:20 PM
91_rs-teal's Avatar
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
i have vacuume canaster taken out, smog pump taken out, but my pcv valve makes a ton of noise. i just bought a new one yesterday and i put it in n it starts, then bogs down to like 650rpm's then jumps to about 2500rpm's then slowly calmes down and when i take it for a test drive it stalls everycorner i take. ive double and trible checked to make shure it was the right one at the store and of corse yes! also bought two of em just in case (vacuume leaks are minimal if any) but just wondering if anyone's had this problem or maybe know/has an idea of what could fix it
Old Jun 7, 2006 | 07:04 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
a vacuum leak at all, can cause idle problems. make sure you dont have a vacuum leak. the lines that connect to the PCV valve can break when you pull the valve out. they get brittle over time and can even get a small crack that can cause issues.
i see youre from caledonia, is that in Michigan?
Old Jun 7, 2006 | 10:17 PM
91_rs-teal's Avatar
k i havnt totally checked every vacuume lines but ill do that thanks, caledonia yes that is near GR!
Old Jun 7, 2006 | 11:52 PM
drdave88's Avatar
Engine: 6.0L
so, youre not too far from mid-michigan motorplex. ill be up there hopefully within a month. ever run at a 1/4 mile? you should. i have yet to meet up w/ someone one on here, especially a fellow v6er.
Old Jun 8, 2006 | 01:34 AM
91_rs-teal's Avatar
ya ill have to see whats goin on. the 1/4 mile no im thinkin 17 if im lucky so if anything ill come up with my buddy - 92 rs 355 3.73 posi soon to be a stick = a good time...lol
Old Jun 21, 2007 | 10:13 PM
91_rs-teal's Avatar
Re: ? about a PCV valve problem
i got a 17.03 last week! crazy 6er im goin to martin this sat be there!
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 12:07 PM
