oil pressure port...help!
Old Jun 14, 2006 | 03:30 PM
z28b88's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8l V6 MPFI
Transmission: 5-speed
im hookin up some gauges and the directions say to hook the oil pressure to an appropriate pressure port on the engine but where would that be??? would i have to drill a new hole or is there somewhere i can just take out a plug screw and insert this one?? please help.... thanks
Old Jun 14, 2006 | 05:08 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
If you are looking to replace the stock gauge... Take out the oil pressure sender (right above the oil filter) and screw in one of the adapters inculded with your gauge. If you don't want to replace, you can buy a t fitting and hook up both to the same port.
Old Jun 14, 2006 | 05:18 PM
z28b88's Avatar
thanks man...im just gonna leave the stock one in cause its in my tach and just hook this one up... i'll post some pics when im done tho...thanks again
Old Jun 14, 2006 | 09:25 PM
z28b88's Avatar
i think i am gonna loose some oil doing this but do u know how much will come out when i take this plug out?
Old Jun 14, 2006 | 09:53 PM
Toehead's Avatar
Shouldnt be much at all. I don't think i even lost a replaceable amount. Just make sure the engine isnt running lol.
Old Jun 14, 2006 | 10:17 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
dont forget to post pics im intrested,.,.thanks
Old Jun 14, 2006 | 11:03 PM
z28b88's Avatar
haha i'll make sure the cars off....
gottfuel - i will post pics just as soon as i get the gauges in and everything hooked up and everything put back together
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
