hard start when cold
Old Jun 15, 2006 | 01:42 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
damnit.. so I got a new fuel injector in,
brand new accel set of 6, I know I did it right!
now when I wake up in the morning(when the car is left outside for long enough)
and try to start the car,
it would crank maybe 10second before it starts up.
my fuel pump is fairly new also, but
its been happening since after the shop
replaced my pump.
they told me its the clogged fuel injector.. thats why i
bought set of injector and put them on.
i do have a new fuel filter,
but I was wondering maybe Im looking at something wrong,
Im gonna go check now, but I do have couple other stuff
that could be the reason.. if any1 can point me out
the usual symptom, I'd apprciate them!
1. I do have a tiny exhaust leak from the manifold,
I wrapped it up with high-temp tape but when car is cold (100-120) I still could hear the leak, after couple min of idling, it's gone.
2. I have 1 sparkplug wire that are in different size from all other 5s. 1 is 8mm and others are all 7mm, could this cause problem or hard start?
3. I think my starter or the solenoid is almost dead,
as sometime the car wouldnt even crank,
and it takes me couple attempt until it starts cranking.
this cant cause a hard start once it starts cranking though right?
thanks in advance!
Old Jun 15, 2006 | 04:30 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
you getting good spark?
id start with the starter sol tho
Old Jun 15, 2006 | 06:35 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
i had the same problem with my 87,but i cant remember what the guy who i sold it too said was wrong with it...if i remember ill get back to ya!
Old Jun 15, 2006 | 06:42 PM
daves12secV6's Avatar
id make sure the starter is turning the engine fast enough,if not that can lead to hard cold starting
Old Jun 16, 2006 | 12:37 AM
sogabe's Avatar
Engine: 3.1L
a little more detail would be..
I do hear like a click when I try to start(i think the starter solenoid is engaging),
but then thats as far as it goes, but everything like stereo works at this point.
and when it doesnt click and engine do start cranking,
it still takes some time til it starts up.
i was reading through the manual today,
it said that when you have wrong visciosity oil,
it can give u hard start.
I do have 188k mile, so I run 20-50W and 2 quarts of oil stabilizer(very thick).. so that might be it.
but ill take the hard start then.. caz i do get a very nice oil pressure out of my 20-50s
my cap'n rotor is both new, and distributor is new too,
but if it wasnt just the oil, ill try some more to figure out!
Old Jun 16, 2006 | 12:47 AM
hmmm 2 quarts of lucas stuff is a bit much,whats the avg temp were u live?
i run 20-50 in mine in the winter with 1 quart lucas(gets below 20* here in the winter sometimes) and in the summer i run sae 50 with 1 quart lucas and never had a problem
Old Jun 16, 2006 | 12:52 AM
sogabe's Avatar
Engine: 3.1L
yeah, it said on the bottle that u could use up to 60% of total capacity in badly worn engine..
i think my engine is badly worn.. so i used 2quarts(out of total 4.5Q)
my valve noise is little quieter, along with stable 40psi oil pressure comparing to before it would bobble around 20 or less when engine is warm.(my oil cooler is helping my psi too)
IMO doesnt thicker oil give more resistance to journals
from rotating = am i losing little power there?
Old Jun 16, 2006 | 12:58 AM
yeah u are, try running some sae 50 without the lucas,i recomend castrol oil,ive used it for years in all my cars,though if u live were it gets really cold in fall/winter i would go back to 20-50
Old Jun 16, 2006 | 01:09 AM
sogabe's Avatar
Engine: 3.1L
i live in north cal..
kinda cold in winter, but never really snow or anything.
summer is realy hot, but top would be 100 or little more just occasionaly.
but yeah until i have money or time to rebuild my engine in the future, i want my car last longer than being a fast car that can brake in a year.. as im a student now and i make no much money, so
i might try the solid 50 castrol and maybe 1 lucas combo then, thanks man
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
