Stalling out
Old Jun 18, 2006 | 09:56 PM
Zooyorkcracker's Avatar
Car: 1991 Firebird
Engine: 3.1
Stalling out
my 91 3.1 firebird will stall out ocasonaly when you press the gas peopl have told me its the timing chain others that its the fuel system,it doesnt happen all the time it only did it once this week. also the computer is putting out code 23 and 45 23 is faulty M.A.T sensor<the pervous owner changed the air filter and air duct taking this out, the 45 is rich exhuast. any advice would be helpful thanks
Old Jun 18, 2006 | 11:00 PM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
hi and welcome!.,.,,. i once had a terrible ideling problem it was due to faulty tps sensor,.,.i would suspect a clogged fuel filter. somtimes there just obstructed enough to let min amount of fuel thru,.,.i wonder though!?does it do it if you mash the gas with yer foot real quick from idle??
Old Jun 19, 2006 | 09:27 AM
Car: 1991 Firebird
Engine: 3.1
yeah it bogs out it dies down whenever you mash the gas all the way down but occasionally it will stall no matter how you press the gas but you wait a few minutes and its all good.
Old Jun 19, 2006 | 12:15 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The rich exhaust(23) is whats causing this.
Mat(45) will possibly cause 23. So first change the MAT. Then check/adjust your tps. Check all your filters as well.
I would then bet you possibly need new plugs as well.
Old Jun 19, 2006 | 01:20 PM
Car: 1991 Firebird
Engine: 3.1
well theres the problem the last owner took out the stock air canister and a portion of air duct so there now where to put the M.A.T. the connector is just hanging there but i do have a new M.A.T. so should i switch back to stock air intake or just tap the new air duct and hope it works thanks for the insight also i already changed the pugs and wires that helped a little considering they were the original ones
Old Jun 19, 2006 | 02:35 PM
Dale's Avatar
Engine: 350 S-TPI
Since you have a bird, create a new intake. Its been posted here alot.
Then yes, tap the new intake, and screw it in.
Old Jun 19, 2006 | 04:23 PM
Car: 1991 Firebird
Engine: 3.1
so i went ahead and taped it out put the new one in and guess what now when you start the car it drops down to 400 to 500 rpms runs like crap and shuts off when you press the gas the computer popped with the M.A.T. and rich exhaust again now it added the M.A.P. sensor and the EGR valve, which i just replaced. so what i am thinking is that their was short in the circuit i just hope i didn't kill the EGR valve i cant even think about it any more
Old Jun 19, 2006 | 05:09 PM
Dale's Avatar
Engine: 350 S-TPI
Did you reset the ecm? (to clear the codes)
If yes, with 3.1s, you have to do whats called an Idle Learn, or basically just drive it 100-150 miles to let it reprogam itself.
Old Jun 20, 2006 | 03:02 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
ouch if u did happen to kill the EGR.. if ur's digital EGR,
they cost so much!
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
