Weird oil pressure reading
Old Jun 28, 2006 | 07:01 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Hey, just noticed today that my oil pressure goes down when I apply throttle at a certain rpm.
Say my car is cruising at 2k rpm with about 60 psi and no throttle at all.
If i give it gas, (same rpms) the oil pressure will go down about 5 pounds. Let off, and it goes back up.
What gives?
Old Jun 29, 2006 | 04:21 PM
wizman073's Avatar
Car: 1987 Firebird
Engine: LB8, 2.8L V6
Transmission: t-5
Cant help you much, but I have just about the opposite problem. Most of the time my needle is pegged above 80, and might drop once in a while to around 60 or so after cruising for a long time. I think the problem is a bad sensor, but I really dont know.
Old Jun 29, 2006 | 05:42 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
for wizman's case
if ur using multi weight oil(which most likely you are)
then as you drive long time and oil gets hot,
the oil gets thinner and thus u get lower oil psi.
Old Jun 29, 2006 | 05:47 PM
dodger65's Avatar
Car: 88 Firebird, 86 T/A
Engine: 3.1/305 short block
Transmission: 700r4 w/ transgo, vette servo/700r4
i'd say bad sending unit...
Old Jun 29, 2006 | 06:07 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
if youre gauge is usually pegged and occasionally moves its more than likely a sending unit. i had the same thing w/ mine and most on here probably have at some point.
Old Jul 2, 2006 | 01:39 PM
pgtr's Avatar
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
What gives?
No idea but FWIW mine suddenly started reading anywhere from zero to 90psi. After cleanign the connector and even removing/cleaning the sender w/ no luck I just bought a cheapo replacement from the parts store and mine works fine again.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
