Woodruff Key for 3.1L V6
Old Jul 5, 2006 | 10:20 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Well I searched, and I need one. I went to NAPA and they don't have the correct one. Anyone have the stock / standard size? Where to get them? Should I just ask the GM dealership?
Old Jul 5, 2006 | 10:47 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
what is this woodruff key? If it's the key that goes in our ignitions... you need to have your current key (if you didn't lose it) ... measured for resistance. Don't go to GM, they charge $40 a key!! Any local key shop should have some if you know your resistance... like $15 a key.
Now, if you don't have your key... I dunno, call GM and ask what you should do.
Now if this isn't what I think it is, sorry :P
Old Jul 6, 2006 | 06:07 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
iirc, it goes in the front of the crank & keeps it aligned w/the......... crank gear?
btw, I've seen an assortment of them in the help section @ AZ a while back, but not sure if they still carry them.
Old Jul 6, 2006 | 08:21 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
Look in the HELP! or Dorman section of your local auto parts store. We carry both brands and have a large selection of woodruff keys where I work.
You can also maybe find them under the Motormite packaging, as they are partnered with Dorman and HELP!
Old Jul 6, 2006 | 10:26 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
If they are the same size as the 5.7 V8 keys (short style), then I have a bunch of them, If you want 10 you're more than welcome to them.
Old Jul 6, 2006 | 04:50 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
They are actually quite long, so its possible that the 350 key's are like the typical 350 keys and are 2 piece.
I ended up calling the chevy dealership and they had them in stock. I couldn't trust the key's in HELP! I've bought HELP! products before only to be let down. This is to cheap and hard to get to to trust a product that MIGHT work. Thanks for your replies.
Instead of making a new topic, I'll ask here. I aquired a radiator from a LB9 IROC w/ the dual fans. Until I'm ready to install the V8 and dual fans, am I able to use the radiator? Or is it that the hoses are reversed (I believe thats what I remember hearing)
Old Jul 6, 2006 | 05:04 PM
Engine: 5.7 / 7.4
the 3.1 rads have teh same hose placements as tehvee-ates. I know as I had to replace my relatively new 2.8 one for a "correct hose placement" rad
just plug the tranny coolant opening sif going auto w/it.
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
