help!!! ignition problem 3.1 v6 camaro
Car: 1991 camaro rs
Engine: 355 sbc
Transmission: tremic 5 speed manual
Hey fellow third gen owners and enthusiests i have a problem and i have tried everything one day a week and a half ago i pulled my car up into the yard to clean it then my mom mowed lawn so i had to move it so i went in and started it backed it up into the driveway and shut it off then a little while later i went out and tried to start it and i got nothing..........huh.. yeah thats what i said...well anyways i took the steering colum apart because a while ago my ignition lock cylinder wires one snapped so i stripped the wire again back and soddered them back together and electrical tape worked fine...so i took the colum apart and noticed the wire broke again but in the lock cylinder so i went and bought a new ignition lock cylinder and key put it in and connected everything up put it back together tried to start it and nothing....what...yeah i said that also....so i thought maybe the starter...so i got under and took the starter off and took it in to auto zone they tested it... it was bad... so i thought yess found the problem..went home put the new starter on hooked eveerything up tried to start it...nothing....what huh... so guys plz help me out here i am stuck and this is my baby and i need to use it and show it the most i can and enjoy every last ride until i put her up so if anyone has any info plz post.
THANKS FELLOW THIRD GENNERS GO F_BODYS
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
When you purchased the new lock cylinder did you get a key with a chip in it or did you just use the keys that came with the cylinder?..
Car: 1991 camaro rs
Engine: 355 sbc
Car: 1991 Firebird
Engine: 3.1L V6
Car: check
Engine: check
Transmission: check
i used the key it came with and it didnt have a chip why?
RBob.
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
