Pls help the Firebird in Taiwan
Old Jul 16, 2006 | 01:56 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi, I will really need your help.
1. Bad smell from the exhaust, I can smell the gas sometime and very stink smoke when driving especially traffic jam, if I keep pump the gas when car is not moving, the exhaust header will comes red very fast, people said the gas is not burned completely, where should I check ?
2. The gas pump senser/connecter/wires are broken, I can't find a right one in Taiwan, my friend added a switch to make the gas pump keep send the gas so I can start the car well and the "engine check" light will not show, the problem is : the car still die sometime when I stop, what should I check ?
3. Computer : the people in garage connect the check computer to my car but sometime they lost the signal, they siad my car computer may broken, so sometime the car is hard to drive, pump the gas but the car doesn't run immediately, is that true?
Thanks for you help, no many people know about the car in Taiwan, sometime they just don't feel like to spend times on it.....
Old Jul 16, 2006 | 04:06 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
1. I would check the cat-convertor, and basic tune up.
2. I dont understand whats broken. If the part is resonable price, I can pick it up for you and mail it. Ive done this for another member on the board.. twice I think.
3. If the ecm is bad, it may do a varity of things. Over there, these are everywhere. So see #2 again.
Old Jul 16, 2006 | 06:53 PM
joekickass's Avatar
Engine: 2.8
Transmission: auto
Thank you Dale.
1. What you mean basic tune up? Which part was included in "basic tune up"?
2. The sensor is control the gas pump, right next the oil pressure sensor and oil filter.
3. Is ecm the car computer or it just part of car computer ?
Thank you.
Joe
Old Jul 17, 2006 | 12:41 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The ECM is the car computer. If they are losing connection, it may not be the car, it may be the scanner (more likely then the ECM being bad)
It sounds like you are talking about the fuel pump relay, which is on the firewall. Tha would keep the Fuel pump from prinming when you turn the key to "on"
For a basic tune up, replace the cap, rotor, spark plugs, spark plug wires, pcv valve, and probably the air filters. That should help get your car running better The Cat sounds like it is clogged for sure. I'm not sure about what you have for emissions laws in taiwan.. But another option to importing a convertor is to take it off and weld a pipe in its place.
Old Jul 17, 2006 | 06:00 AM
joekickass's Avatar
Engine: 2.8
Transmission: auto
Thank you Toehead:
1. Is the scanner means that thing they use to check the ECM ? I have a different years firebird, can I replace it if the problem is ECM? or I should buy one from Hawks-Thirdgen, it shows US50 for one.
2. Thats what I talking about...fuel pump relay, thank you man! not only the relay was broken, but the connceter and the wire....the cat is too hot.
3. basic tune up: once again, my poor English and poor cars knowledge, I am nout sure what is cap, rotor, pcv valve, what can I get the picture? from hawkthirdgen? There is no converter on my car....the middle / end of exhaust have been changed last week but I still smell the gas, people told me if there is no convertor in my car the air may become stinky, but smelling gas is not right!
Old Jul 17, 2006 | 09:13 AM
Toehead's Avatar
To see if the ECM is at least responding, try to pull the error codes. You can read the codes yourself with a paperclip.
Q: How can I display the error codes from a Service Engine Light?
A: If your car does not have the 12 pin DLC connector, you may not be able to manually "flash" your trouble codes. The language "may be possible" appears to suggest that this method should work with most, if not all, 12 pin DLC equipped cars.
THE CONNECTOR
----------------------- | 1 2 3 4 5 6 | | 7 8 9 10 11 12 | -----------------------
DISPLAYING THE TROUBLE CODES
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6), then turning the ignition to the on position without starting the engine will flash the "Service Engine Soon" light in the following sequence: flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause flash, pause, flash-flash, long pause Following this "12" code repeating three times will come any trouble codes stored, flashing each of them three times. If you do not see the "12" flash three times, your diagnostic circuit is defective. Some vehicles will display stored trouble codes, then "12" again, followed by energizing "most system controlled relays." The fuel pump relay will not energize. The idle air control valve will fully extend to enable checking minimum idle speed.
CLEARING THE TROUBLE CODES
Turn the keyswitch to the off position. To clear any trouble codes, disconnect the power feed for 30 seconds. If this is done at the battery, and your car stereo is equipped and programmed with a four digit pin code, you may have to re-enter that as well to use your stereo again. A better place to remove power is at the fuse.
TROUBLE CODES
12.No reference pulses to Electronic Control Module (ECM).
13.Oxygen sensor signal stays lean during warm engine cruise
14.High temperature indicated at engine coolant temp sensor
15.Low temperature indicated at engine coolant temp sensor
16.High battery voltage OR Direct inition system open or shorted to ground
17.RPM signal problem
18-20.N/A
21.High voltage at throttle positon sensor
22.Low voltage at throttle positon sensor OR Fuel cutoff relay circuit open or shorted to ground
23.Low temperature at manifold air temperature sensor OR Throttle position sensor error
24.Circuit fault in vehicle speed sensor
25.High temperature at manifold air temperature sensor OR Vacuum switching valve circuit open or shorted to ground OR High voltage at ATS sensor
26.Fault in quad driver module
27.Fault in 2nd gear switch
28.Fault in 3rd gear switch
29.Fault in 4th gear switch
30.N/A
31.Low voltage at manifold absolute pressure sensor OR Fuel injector OR Park or neutral switch OR CAM diagnostic OR Governor malfunction OR Wastegate overboost OR Wastegate eletrical signal open or shorted to ground
32.Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve
33.High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34.Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
35.Idle speed can not be set to desired RPM
36.Burn off at mass air flow sensor OR Problem in transmission shift OR Fault in direct ignition system OR Missing pulses in electronic spark timing signal
37.N/A
38.Fault in torque converter clutch brake switch
39.Fault in torque converter clutch circuit
40.N/A
41.Fault at cam sensor OR Cylinder select error OR Tach input error
42.Fault at electronic spark timing circuit OR Fault at direct ignition system OR Fault at fuel cutoff relay circuit
43.Low voltage at electronic spark timing circuit
44.Oxygen sensor lean
45.Oxygen sensor rich
46.Fault at vehicle anti-theft sytem OR Fault at power steering switch
47.Problem at Electronic Control Module (ECM)
48.Misfire
49.Vacuum leak
50.N/A
51.PROM error
52.Problem at Electronic Control Module (ECM) - Missing fuel calpac missing OR Analog to digital converter error OR Fault at quad driver module OR Low voltage at oil temperature sensor
53.High voltage at battery OR High voltage at exhaust gas recirculation valve OR Voltage reference error OR Problem at vehicle anti-theft system
54.Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
55.Problem at Electronic Control Module (ECM) - ECM failure OR Serial bus error OR Fuel lean malfunction
56.Low coolant or corrosivity OR Fault in port throttle system vacuum sensor
57.N/A
58.Problem at vehicle anti-theft system
59-60.N/A
61.Oxygen sensor degraded OR Port throttle system error OR Cruise control problems
62.Gear switch input diagnostics OR High voltage at oil temperature sensor OR Fault in cruise control- vacuum solenoid circuit
63.High voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Fault at right oxygen sensor
64.Low voltage at manifold absolute pressure sensor OR Fault in exhaust gas recirculation valve OR Right oxygen sensor lean
65.Failure at exhaust gas recirculation valve OR Faulure at injector peak/hold diagnostic OR Right oxygen sensor rich OR Fault at cruise control position sensor
66.Internal reset of Electronic Control Module (ECM)
67.Fault at cruise control switch
68.Fault at cruise control switch
69.Fault at air conditioner pressure switch
70-87.N/A
88.Internal reset of Electronic Control Module (ECM)
| 1 2 3 4 5 6 |
| 7 8 9 10 11 12 |
Old Jul 17, 2006 | 09:46 AM
Dale's Avatar
Engine: 350 S-TPI
Scanner/ECM. Depending on the year/engine and some other info, the ecm in your other car may be the same, it may be different. It will have an 8 digit part number on it. Thats the first step, then pull the cover off it, and you will have whats called a promchip inside. It will have a 4 digit code on it like "AUJR" or something, you will have to make that match also.
Fuel pump relay. If thats bad, that is a problem. If you need a new one, and part of a harness, let me know. I'll go cut one off a jy car, or go and/or go get a new relay from a parts store and ship it over.
Tuneup, if you dont know what them parts are, you may want to take it somewhere and have them do it. But all of it is fairly simple and just takes a few tools.
Cat-converter. If its been removed, you will have a burnt gas smell, not a raw gas smell. If any part is glowing red, that means its getting WAY to hot from..
1.backed-up exhaust pressure
2.running rich IE putting in WAY to much gas and its burning in places it shouldnt
3.its running way to lean IE not enough gas
Your saying you smell raw gas makes me belive its running rich, or backed up exhaust. You can see if you have a cat-convertor yourself, it would look kinda like a muffler, but its placed under the passanger floorboard/seat.
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
