Picture request of serpitine setup
Old Jul 19, 2006 | 07:22 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Anyone have a picture of the serpetine setup on the 3.1L V6 complete, perferablly out of the car picture from the front of the motor, but I'll take what I can get. Thanks
Old Jul 19, 2006 | 07:31 PM
daves12secV6's Avatar
best i can do.not sure if its the same as the 91+ when i got my 3.1 longblock it had no accessorys on it so i just bolted my old stuff back on
Old Jul 19, 2006 | 08:42 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Great picture, thanks. On the AIR Polution Pump there is a threaded hole that goes all the way through, I don't remember what goes there. Anyone know what Im talking about? If not, I can take a picture tomorrow.
Old Jul 19, 2006 | 10:27 PM
couldnt tell ya caus emine dosent have a air pump.just an idler pulley
Old Jul 20, 2006 | 05:10 AM
AlwaysDanked's Avatar
Car: 1991 Camaro RS
Engine: 3.1mpfi swapping in a 2.8mpfi
Axle/Gears: non-posi rear
thats not what mine looks like, that looks like a 2.8. id show u mine but its not that clear.
Old Jul 20, 2006 | 07:06 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Here is what Im talking about:
Old Jul 20, 2006 | 07:23 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
This is a really bad pic. But I think the circled part is what your looking for.
I'll see if I can get a better pic tomorrow.
Old Jul 20, 2006 | 08:16 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
This is the best I can do, the picture I have from the front is blocked by the air filter.
Old Jul 22, 2006 | 06:52 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Ok, I managed to put some brackets on. Thanks everyone for the pictures, they helped alot.
Here is what Im dealing with:
And here are the brackets I have left to place (minus the lower right one, found that):
Anyone tell me where the other two go?
Old Jul 22, 2006 | 10:57 PM
Car: 1991 Firebird
Engine: 3.1L V6
The other two go here:
Old Jul 24, 2006 | 09:52 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Thanks for the picture man, that explains why I could find it.
Old Aug 7, 2006 | 09:14 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Alright, the new motor is in her, everything hooked up, and hopefully ready to fire tomorrow.
I still need to know if anything goes into the threaded hole RIGHT above the water pump. If you look at the front shot of my new motor in the above post, you can see the threaded hole Im talking about above the water pump pulley and to the right of the balancer.
I also need to know about a vacuum hose. There are two connections on the back of the upper plemium. The connection to the left, passenger side, I have no idea what connects to that. On the upper plenium that I got with the motor, it has the hoes that attaches to it, but I have no idea where it goes. Second question, is it vital?
After that, I just have to find the bolt that goes into the back of the ac compressor to hold the backet that connects to the upper plenium and shes a fire!
Old Aug 7, 2006 | 09:16 PM
its for the heater/ac vents.look for a lil hard plastic vacum line in the car on the passenger side firewall area and near the blower motor
Old Aug 14, 2006 | 09:40 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Thanks dave, it was right there waiting to be found.
After all that, I come to find out the injectors are plugged. Thats ok, engines in, sprayed some gas in and she fired, and the injectors are a pretty easy fix. I cant wait
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
downsouthboy
Aug 29, 2015 11:29 AM
chubsworth
Aug 26, 2015 02:34 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
